Old 07-26-2019, 05:13 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Then.... The second part of the story...... I had a Ridetech 4 link with coil-overs installed …….. after installation I noticed that when jacking the car up to get a rear tire off, I had to deflate the tire and squeeze it down towards the rim to get it out of the wheel well...….Put it back on the same way then inflate...…. Humm….. So.... Another thing that needed some attention...…. I assumed that the shocks were at their travel limit and not letting the rear drop enough to cause the tire issue...… So, After checking with Ridetech the shocks were mounted O.K...…. But I had room to raise the shock mount on the housing up another Inch without any issues as this would give me another inch of downward travel to get the tire out...….. LOL..... So, After the changes I go to put a tire off and the same situation.….. WTF !!!!……… Can't be...…..So....As I'm looking around under the car...… I see the real Issue.....The car has a 9" Ford rear in the car (lower Pinion position than a Chevy) and I see that the driveshaft it hitting on the cross bar attached to the supplied 4 Link assy...…
Cut the contact area out and lowered it 1.5" and everything is good again...….. Now if something happens on the Road Tour it will be a little easier to change a tire...… LOL..... This Car stuff is Hard !!!!
The Following User Says Thank You to kwhizz For This Useful Post:
camcojb (07-28-2019)
  #282
Old 07-26-2019, 08:11 PM
It's a never ending story! It'll definitely keep your mind busy. Glad you figured it out.
Old 07-27-2019, 09:04 PM
glassman's Avatar
glassman glassman is offline
well, if u need to plug a tire on the road tour, I've got your kit. but ill be in the west
Mike
Old 07-28-2019, 04:54 AM
kwhizz's Avatar
LOL...…..No worries...…. She got me another one for Christmas !!!!!!
Old 07-30-2019, 03:06 PM
NAPA 68 NAPA 68 is offline
I'm convinced this build is possessed! You have fought tooth and nail on almost every facet!
I admire your persistence!
The Following 2 Users Say Thank You to NAPA 68 For This Useful Post:
kwhizz (07-30-2019), waynieZ (07-30-2019)
  #286
Old 08-11-2019, 06:23 AM
kwhizz's Avatar
Does it ever end...…. I've had 2 different Ring and Pinions gears installed in the car (9" Ford) ...… The first one howled really bad...…. Had another set put in and it was quiet until it heated up and then it had the back ground Howl...….. Can't imagine driving on the Good-Guys Road Tour and having to listen to that for a week...… Ordered a Quiet Zone Unit from Johns Industries...… Should be here next week...… Hope it's what they say it is...….. The car is getting very close ………(those Famous last words..... LOL)
waynieZ (08-11-2019)
  #287
Old 08-11-2019, 06:34 AM
I hope the new one fixes it.
The Following User Says Thank You to waynieZ For This Useful Post:
kwhizz (08-11-2019)
  #288
Old 08-11-2019, 09:22 AM
dhutton dhutton is offline
Are you using synthetic gear lube? Try dino on the next fill usually quieter in my experience.
Don.
Old 08-11-2019, 11:19 AM
minendrews68 minendrews68 is offline
All finished in the Engine compartment...… New A/C lines and fuse panel relocated...…. Just need to get the A/C charged..... Tracey is working on the seat and can't wait do put some miles on this "Beater".....
Dang son! that's wall to wall engine in that compartment. I bet working on it is a mess... Looks really good though.
The Following User Says Thank You to minendrews68 For This Useful Post:
kwhizz (08-12-2019)
  #290
Old 08-11-2019, 12:41 PM
kwhizz's Avatar
Don.
Non-synthetic is what I was told to use
