Old 08-01-2019, 11:59 AM
syborg tt's Avatar
Freaking Awesome !!!
So do you plan to make flare so you can fir a wider tire ?
Originally Posted by craig510 View Post
Been working on some flares.
marty-mj
Old 08-01-2019, 06:52 PM
Flares, shmares. Go for the second line up. Get the angle grinder. The first cut is never the deepest, but we get better cutting as we practice . . .
The Following User Says Thank You to rustomatic For This Useful Post:
Beechy (08-02-2019)
  #313
Old 08-03-2019, 09:17 PM
craig510's Avatar
craig510 craig510 is offline
My little guy likes to get in on the action:
Still will be able to keep the trim:
Super nice fit for fusion TIG welding.
The Following User Says Thank You to craig510 For This Useful Post:
Roscoe03 (09-01-2019)
  #314
Old 08-03-2019, 09:22 PM
craig510's Avatar
No thanks. I’ll keep it sanitary and stock looking. The body saw and 80 grit on a right angle die grinder to get the gaps perfect for hours of TIG.
Old 08-04-2019, 09:43 PM
craig510's Avatar
Originally Posted by Andyd View Post
Looks great. What are you using to make the flares? Other fenders? Hand forming?
Sent from my CLT-L04 using Tapatalk
Thanks.
I used quarter panel patch sections for the basic shapes but they have been heavily reworked. The fronts are 71 Mustang rear and the rears are W123 Mercedes. I had to narrow the front lips and flatten the rears plus form the contour so that it matches the factory lines. Plus a bunch of shrinker/ stretcher work and sectioning to adjust the radius.
Old 08-30-2019, 10:12 PM
craig510's Avatar
Had a good time at GoodGuys. Got 4th in a tight 4 way battle for street machine. Made it into the shootout and got knocked out first round. At least I put in a good showing and made the winner work for it. It was a quick clean run but he got me by about 3 tenths.
Sitting in the pits with raw metal and all
Near Perfect fit for TIG welding
And a Video to prove it:
Enjoy - Craig
The Following 2 Users Say Thank You to craig510 For This Useful Post:
booah (08-31-2019), Roscoe03 (09-01-2019)
  #317
Old 08-31-2019, 06:43 AM
Kcrain Kcrain is online now
Boy those flares really blend in and fit the car. When painted probably won’t be noticeable without parking beside a stocker. Look great Keith
The Following User Says Thank You to Kcrain For This Useful Post:
craig510 (08-31-2019)
  #318
Old 08-31-2019, 06:15 PM
hackster's Avatar
hackster hackster is offline
Stellar work as always man.
I friggin love this car and what you are doing.
Sean
The Following User Says Thank You to hackster For This Useful Post:
  #319
Old 09-02-2019, 09:22 PM
craig510's Avatar
Sean
Thanks Sean, not as fast as you but I think I have a little more attention to detail. You get out and wheel more though so I think you win.
I don't think I shared my dyno pull. It sounded absoultly amazing, then the numbers came up and it was a little disapointing. Only 318hp and 300ft-lb at the tire. It was about 98 degrees and I only had 28 deg timing. Solid roller and 9.7:1 with Arco 91 octane. It feels better and runs cooler at 34 degrees.
Old 09-02-2019, 10:32 PM
Dave Pratt's Avatar
Dave Pratt Dave Pratt is offline
Man I've got a new favourite car! Great work it's beyond cool...
The Following User Says Thank You to Dave Pratt For This Useful Post:
craig510 (09-05-2019)
