  #36
Old 08-09-2019, 09:51 AM
Fair Fair is offline
continued from above
CHASSIS WIRING & MOTEC ECU INSTALL
Like the brake line system below, we bit off a lot of work when we decided to re-wire this entire car. Every wire, every module, every light bulb got re-wired. We started with a Painless Wiring "Pro Touring" chassis harness, pared it back to the systems we needed, then integrated the Motec engine harness that G-SPEED built.
I cannot emphasize enough how much work a total re-wire job is. Sure, we lopped off probably 30 pounds of the 50 pound chassis harness we pulled out, but it took 200 hours+ to get there. Ryan had to make all new wiring diagrams for the entire car, a whole binder full of them. Mount every relay and fuse box, ground busses, soldering terminations with motorsports Deutch connectors and pins on everything. Vibration mounts, harness sleeving, bulkhead connections, and on and on.
The electric assist steering system was another system of wiring - this has a 100 amp fuse to power it. EPAS draws some serious amps when you have to turn 335mm Hoosiers up front.
There were a more rounds of Deutch connector and pin orders, lots of hours spent stripping and pinning wires, and switch panels for a dozen switches, push buttons, and dials.
During the final weeks that the chassis wiring was going on, the guys at G-SPEED had the engine harness nearly done. I was out at MSR-Cresson for a race on the weekend and stopped by their shop to snap some pics. The costs involved for a Motec ECU and harness are also not for the faint of heart - but a Motec M150 has a lot of data inputs and programming potential. We're still exploring the limits of that.
A month after my shop visit the packages from G-SPEED arrived with the harness, M150 ECU, and other goodies.
Then that was integrated with the rest of the power supply and wiring already in the car. It looks like a nightmare here, but Ryan was meticulously going through each system, striping wires, heat shrinking ends, and testing circuits. He never released "the magic smoke", which all wiring jobs can do - once.
The sensor package from G-SPEED included things we normally do not monitor, like fuel system pressure and temps. All of the normal oil and water pressures and temps, traction control sensor integration into the ABS system, even crankcase pressure (we added the sensor later).
All of this Motec goodness talks via CAN to the AiM MXG color digital dash, which also has GPS and acclerometers for predictive lap timing and data logging.
continued below
The Following 2 Users Say Thank You to Fair For This Useful Post:
CCS (08-13-2019), fleetus macmullitz (08-13-2019)
