08-10-2019, 07:53 AM
Clutch parts, slave and transmission harness sold
The Following User Says Thank You to gnx7 For This Useful Post:
09-22-2019, 07:48 PM
Somebody buy this and build something bad ass with it!
I have an n/a 800hp 441ci LS engine that could pair up well with this
05-03-2020, 09:49 PM
transmission/diff/coolers/lines/eLSD controller/both axles/outer hubs tentatively sold
05-09-2020, 10:58 AM
Trans/shift linkage/diff/eLSD controller, coolers/lines, both axles and rubber isolators sold
Here is what I have:
TR6070 with cooler/lines $SOLD$
TR6070 diff with cooler/lines $SOLD$
both axles $SOLD$
shifter linkage $SOLD$
diff isolator bushings/mounts $SOLD$
eLSD actuator/pump $SOLD$
2016 Z06 Corvette 7 speed manual: (10K miles approx) rear cradle, upper/lower A-arms, uprights (where the axles slide into on the outer portion at the wheels... no hubs/studs/bearings), leaf spring, sway bar and end links (no brakes... but I have them for additional cost). $750
2015 Z06 Corvette: (6K miles approx) front cradle, upper/lower A-arms, front hubs/uprights/bearings/factory wheel studs..... no sway bar or leaf spring: $700
2015 z06 steering rack for the 14.5" steel brake option $400
2015 Z06 front 14.5" steel rotors, red calipers/6K mile brake pads
2015 Z06 rear 14.2" steel rotors, red calipers/6K mile brake pads $1600 (will not separate the brakes)
C7 Z06 carbon torque tube $650
C7 Z06 carbon driveshaft $500
Clutch slave $SOLD$
transmission harness $SOLD$
leaf spring Front $SOLD$ (rear still available)
twin disc clutch/pressure plate $150 $SOLD$
05-20-2020, 07:27 AM
both axles $SOLD$
2016 Z06 Corvette 7 speed manual: (10K miles approx) rear cradle, upper/lower A-arms, uprights (where the axles slide into on the outer portion at the wheels), leaf spring, sway bar and end links (no brakes... but I have them for additional cost). $750
2015 Z06 Corvette: (6K miles approx) front cradle, upper/lower A-arms, front hubs/uprights/bearings/factory wheel studs (No sway bar or leaf spring): $750
2015 z06 steering rack for the 14.5" steel brake option $SOLD
2015 Z06 rear 14.2" steel rotors, red calipers/6K mile brake pads $SOLD(do not want to separate these from each other. It is being sold as a complete front/rear setup. Pics up next week)
C7 Z06 carbon torque tube 10K miles $650
C7 Z06 carbon driveshaft 10K miles $500
Clutch slave $SOLD$
Brakes and steering rack related items sold
09-13-2020, 12:19 PM
This is the updated parts list on what is left:
2016 Z06 Corvette: (10K miles approx) rear cradle, upper/lower A-arms, uprights (where the axles slide into on the outer portion at the wheels), leaf spring, sway bar and end links (no brakes). $700
2015 Z06 Corvette: (6K miles approx) front upper/lower A-arms, front hubs/uprights/bearings/factory wheel studs (No sway bar or leaf spring or cradle): $600
buy both for $1K
C6 non Z06 aluminum manual torque tube and driveshaft approx 100K miles (I would rebuild/replace the guibos/rubber isolaters) $250
01-29-2021, 09:23 AM
Sold the entire front suspension this week. Here is the updated list:
2016 Z06 Corvette: (10K miles approx) rear upper/lower A-arms, uprights (where the axles slide into on the outer portion at the wheels), Does no have hubs/bearings that bolts into the uprights (easily purchased new though) rear leaf spring, sway bar and end links (no brakes). $400
rear cradle is sold
buy both for $1000 plus shipping
02-26-2021, 07:53 AM
Sold the torque tube/dshaft.... so here is the updated parts list:
2016 Z06 Corvette: (10K miles approx) REAR upper/lower A-arms, uprights (where the axles slide into on the outer portion at the wheels), Does no have hubs/bearings that bolts into the uprights (easily purchased new though) rear leaf spring, sway bar and end links (no brakes). $400
rear cradle is sold also
10-06-2019, 11:01 AM
Just picked up a used C6 aluminum torque tube/bellhousing and dshaft so that can be easily shortened to swap this into something... or lengthened if that is the goal.
$150
10-27-2019, 11:22 AM
Front leaf spring sold
