Old 07-11-2019, 05:58 PM
hotrodfuelhose's Avatar
hotrodfuelhose hotrodfuelhose is offline
Cool Very well done
Very well done, nice build!
http://www.hotrodfuelhose.com
The Following User Says Thank You to hotrodfuelhose For This Useful Post:
Goosesdad (07-16-2019)
  #322
Old 08-08-2019, 10:51 PM
Goosesdad's Avatar
Fab'd up the remote fill and dip stick for the dry sump tank.
Started with adding a 1/2" NPT port for the dip stick and a -12AN for the fill to the top section of the tank.
Added this radius'd AL tube as an internal guide for the dip stick. Using Lokar Universal Locking dipstick.
Fab'd up this little remote filler box with a filler neck and a -12AN port.
The start of the sheet metal access ports. This one is for the dipstick.
Blended them into the upper portion of the fender. Still have plenty of clearance even when the hood is closed.
Here's the underside.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
syborg tt (12-28-2020)
  #323
Old 08-08-2019, 11:33 PM
Nicely done!
Old 08-09-2019, 12:52 AM
Dave Pratt's Avatar
Dave Pratt Dave Pratt is offline
damn nice...
Old 08-09-2019, 07:09 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Are you going to weld the old fill port closed? I'll need to do something similar on my car and was thinking of welding it up.
Instagram- camaroaj
Old 08-12-2019, 09:18 AM
Goosesdad's Avatar
Nicely done!
Originally Posted by Dave Pratt View Post
damn nice...
Thanks !
Have a great day!
John
My Build Thread:
Old 08-12-2019, 09:20 AM
Goosesdad's Avatar
Hi AJ. I don't think I will weld it closed. The cap is really tight so I don't think there is risk of it coming loose. Interested in your thoughts.
Have a great day!
John
My Build Thread:
Old 08-12-2019, 10:03 AM
CamaroAJ's Avatar
I was thinking more for an aesthetics aspect having something useless like it was just thrown together and not though about. Well, yours is hidden so that really wouldn't be the case for you. I think mine will be visible.
Instagram- camaroaj
Old 08-12-2019, 12:05 PM
Goosesdad's Avatar
Agreed...just saw your latest pics and see what you're getting at, your's will be visible, I actually think it's going to look bitchen seeing the tank. I bet you can get either Peterson or Aviaid to build the tank without the filler neck. Not sure if you have the tank yet.
Have a great day!
John
My Build Thread:
Old 08-27-2019, 12:09 PM
Goosesdad's Avatar
Deck lid support. Fab'd up this little bracket and used a support from Lift Supports Depot. Couldn't make one of the prefab'd ones from our normal go-to companies work because of the fiberglass lid... I did try.
Used nutserts to attach the bracket to the lid. I ended up with a 58 lb. support, though I don't have the spoiler on yet, it should still be stout enough.
Have a great day!
John
My Build Thread:
