Old 08-12-2019, 01:52 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Lines need to run low for a gravity feed so the pump works right. Lucky the LS7 pan has two drain bolts so you only have to worry about fitting the tank. Look
at Hellfire and Jackass 2.0 builds as to how Mark has put the tanks in that area.
Instagram- camaroaj
The Following User Says Thank You to CamaroAJ For This Useful Post:
colorado80439 (08-13-2019)
