Old 08-13-2019, 07:27 PM
Originally Posted by Matt@BOS View Post
No doubt! More volume is always better.
With regard to this post, if "behind the inner fender" means cut into the cowl, then I'd recommend going with a 3 gallon as well since you're going through the trouble of making something fit.
On a side note, I'd be curious to know if Steilow added to the Peterson reservoir on his builds. All of the ones I remember seeing mounted the dry sump against the core support, and if my memory serves, they were all 2.5 gallon because there is no room to go any deeper.
Matt
That's what she said....
The Following User Says Thank You to raustinss For This Useful Post:
Flash68 (08-14-2019)
