Old 08-27-2019, 08:37 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Got a little swap done this weekend and got both fender wells on, the inner fenders looks almost like new metal with nothing covering them! - will need to epoxy prime these after bits of rust is repaired. Then I started fabing block off plates for fenders
Check out new cold air - what ya think cut a hole in center of T/A hood and put a cone filter on top? man gotta cut back on drinkin and workin at the same time?
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
The Following User Says Thank You to ZMAN1969 For This Useful Post:
Roscoe03 (08-27-2019)
  #72
Old 08-28-2019, 05:00 AM
Tim john--- Tim john--- is offline
Post
Do not tighten up the inner fenders wells until you have the front end, as in headlight surrounds, core support, lower valance, hood on and aligned etc. assembled. The inner wheel wells will prevent you from obtaining perfect gaps. Tighten them after final assembly. Love the 69 Trans Am's.
Tim john---
The Following User Says Thank You to Tim john--- For This Useful Post:
ZMAN1969 (08-29-2019)
  #73
Old 10-06-2019, 10:52 AM
ZMAN1969's Avatar
Tim john---
Tim John that's a good tip!
have a little update, got some work done on the air intake just need to find someone to tig it for me
happy with results never fabbed anything like this before so had to make a few cuts and see where it went. Definitely not professional I'm sure most would cut tubing with a band saw? I made due with my Sawzall
now once its been welded up- trying to decide what finish to put on it - raw? powder coat? bedliner? insulate it?
LS6 6speed
1999 Firehawk
Old 10-06-2019, 11:08 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Nice updates. Who's doing your work in Dallas?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 10-06-2019, 06:09 PM
ZMAN1969's Avatar
doing my work?
LS6 6speed
1999 Firehawk
Old 10-07-2019, 12:23 AM
Brianstanford Brianstanford is offline
lookin good! think i'm gonna spray paint my air intake satin black. i'm in texas also, south of houston
Instagram @brianstanford
Old 10-07-2019, 10:22 AM
214Chevy's Avatar
Originally Posted by ZMAN1969 View Post
doing my work?
Yes...the work on your car. Or are you the man himself with all of the skills?
'68 C10 swb
'72 Chevelle
Old 10-07-2019, 06:44 PM
ZMAN1969's Avatar
Son and I are building but gonna farm out the bodywork. and as far as skills I'm trying to get some. A buddy of mine advised not to quit my day job
well Howdy I'm thinking satin black too but textured? hence my thought of bedliner
LS6 6speed
1999 Firehawk
Old 10-08-2019, 07:56 AM
214Chevy's Avatar
I think I saw this car at a shop a few years back over off of Forney Rd in the Pleasant Grove area of Dallas. Behind that tire shop. Am I correct?
'68 C10 swb
'72 Chevelle
Old 10-08-2019, 10:16 AM
ScotI ScotI is offline
My vote would be any coating that helps insulate as a priority.
If you can do a Ceramic type barrier coating that insulates inside & out, you should. You can also then wrap the outside w/a secondary heat barrier (flexible exhaust wrap). Anything that helps prevent under hood heat from transferring which will impact the incoming air.
