  #21
Old 10-20-2019, 06:06 PM
Gmachine1911's Avatar
Originally Posted by Highroller54 View Post
Hi Shane, just looked through your build thread from the beginning. Wow!
I have a couple questions that I hope you will help me with.
What kind of undercoating did you use? And how did you build the rear seat? Did you build off the factory metal frame or is it all foam? I need exactly what you have built for my 64 nova. I’m sure I can handle the foam shaping part but the rest I need a plan on lol Thanks! Chad.
Hey Chad, no problem, glad to answer any questions you have. The coating I used is the Upol Raptorliner. It’s bedliner and sprays on very nicely. If I recall correctly, I sprayed it at about 80 psi which gave me a very fine texture but you can experiment with lower pressures to get the texture you want. I did use the rear seat frame but it’s been modified for mini tub clearance and then I took the car to Shane Lisle at Sewn Tight Interiors in Louisville, KY and he worked his magic to make it match the front Recaros. Per my request, he removed the springs from the rear seat back to make it much thinner then it was originally since I’m running a roll bar and still wanted to have the ability to use the rear seat for my teenage boys. It actually sits quite comfortable but the legroom is severely limited so It doesn’t see much use. The 67 Nova I’m building wont have a roll bar in it for that reason, so it’ll be more of a “family car”!
Originally Posted by Dave Pratt View Post
I really like the look of that console.I'm not running one in my 69 but had been thinking about something along those lines.Yours looks great...nice work
Thank you, Dave! I had never run a console before in all the years I’ve owned the car but after getting it on the road and doing longer road trips, I started to appreciate the need for having some extra space to keep my junk!
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
