Old 11-09-2019, 10:00 PM
Gmachine1911's Avatar
After getting the mini tubs and new outer wheel house fitted up, I mocked up the rear quarters, tail panel, trunk and filler panel to be sure things were on track.
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
Old 11-09-2019, 10:05 PM
Next, I got started removing the old upper cowl panel (what was left of it) as well as the inner and outer side cowl panels...
Shane
#theanchorholds
Old 11-09-2019, 10:09 PM
Later that afternoon, I had the new parts mocked up. Had to re-check to make sure it was still square, tweaked some areas for better fitment and finished up a few stray items in the back but overall everything lined up well.
Shane
#theanchorholds
The Following User Says Thank You to Gmachine1911 For This Useful Post:
Roscoe03 (11-11-2019)
Old 11-09-2019, 10:12 PM
Then, this thing of beauty showed up...
Shane
#theanchorholds
Old 11-09-2019, 10:16 PM
More parts...
Shane
#theanchorholds
Old 11-09-2019, 10:20 PM
So catching up to today, put in a long day today but accomplished what I set out to get done. First of all, I bought me a 120v spot welder from Harbor Freight. Wasn’t sure how that was gonna work out but it actually worked quite well. I knew I’d be limited on where I could use it but just being able to do the firewall and cowl panels alone would be worth it. Here’s a shot of the firewall after welding it across the top. Should make the bodywork side much easier.
Shane
#theanchorholds
Old 11-09-2019, 10:31 PM
Next up I got the firewall/floor pan supports fitted up and welded in. These fit pretty good as well and I used the subframe to make sure everything was in the right spot. So glad to have that part done! I also managed to get my hand with a 60 grit flapper disc, right thru the glove! Word to the wise, wear leather gloves for that stuff.
Also, just some random pics. Next is to get the thing off the metal frame and onto some jack stands or casters of some type. Still have some welding to do and plenty of welds to dress. After that, i need to get the torque boxes and subframe connectors welded in and get the extra holes in the firewall and core support filled.
Shane
#theanchorholds
