Old 12-03-2019, 07:39 PM
hackster's Avatar
hackster hackster is offline
Originally Posted by St3v3 View Post
Dude I watched that the day it was released....So friggin awesome. 1000 wheel hp.
Got the other valve springs, seats, seals and retainers all installed last week.
Just been tinkering with it the last few days since I have been battling a cold, its getting worse.
Here are some pics of why I decided to do the trunion upgrade and some of how.
You can see that the stock trunion only has about 40% of an actual shaft so the bearing puts a lot of pressure on that one spot...not that this is bad wear for 200k plus miles. But when you put in heavier valve springs it really puts pressure on those bearings and shaft.
and here is the other major problem. The factory bearings are just pressed into the rocker arm itself, there is no keeper in there and the bearing is a roller bearing with no keeper on the inside so if things come apart, these end up everywhere.
I chose to do the BTR TRK002 upgrade after a lot of reading up on what works.
You can see how huge of an upgrade this is.
Fully captured USA made Roller bearings
A full round shaft for bearings to ride on and fully captured with washers and clips.
The process was really straight forward with the right tools.
Totally worth the $39.00 in my opinion.
Tore down the front of the engine and built some tools.
A sharp eye will note the stock VVT 1 bolt camshaft still in place. I did elect to build some 5/16" dowels to keep the lifters up in their tray while Asher and I hot swapped the cam.
New power maker installed. Its a BTR Stage 2 blower cam I can post up the specs if people are curious. Specifically built for the LSA setup.
New 3 bolt gear and new timing cover installed and torqued. Crank pulley pinned again and back on.
Onto the next phase. Pulled off the blower snout and got to cleaning.
Stocker
Not Stocker
CNC ported Blower snout
All reinstalled with a griptech 2.45" pullley for a lot more air this go around.
Going to do the Mark Williams boosted 102mm throttle body to go with the snout just need it to show up.
