Old 02-22-2020, 07:03 PM
bd8134 bd8134 is offline
Default Mounting / hiding a mast style antenna
I want to put an electric mast retractable antenna in my car but I do not want to have the regular bezel and mounting nut visible / above the fender. I was thinking about making a bracket which the bezel and mounting nut fixes to so just the top tip of the antenna mast protrudes through a hole in the fender so that it sits flush.
When the radio comes on the mast will extend through the hole in the fender.
I am thinking the tip of the mast might need to be larger then the stem of the mast so I might have to make a larger hole than just the tip. Also I will not be able to lean the antenna backwards as it will require a bigger or oblong hole.
Has anyone some ideas how to do this or used an antenna they liked for this purpose. I do not want to do a sunken hole for the antenna.
I also do not want to use a window, foil, stick on type antenna nor a shark fin.
I enjoy listening to the radio and specifically HD radio.
Old 02-23-2020, 07:54 AM
Default Old School 'French mounting'
https://www.youtube.com/watch?v=9xGExIGw-js
Old 02-23-2020, 08:36 AM
Thanks for the link. Ah they call the ‘sunken mount’ a French mount.
I did not want do this style either.
Any other suggestions?
Old 02-23-2020, 11:59 AM
dhutton dhutton is offline
This guy hid it in the spoiler
https://www.camaros.net/forums/19-el...r-install.html
Old 02-23-2020, 12:44 PM
Perry Mitchell Perry Mitchell is offline
I believe this is the look you are looking for. The top of the mast has not been painted body color yet.
Old 02-23-2020, 12:45 PM
Default avoid the Mast all together?
https://www.classicindustries.com/pr...SABEgLjwvD_BwE
Old 02-23-2020, 07:02 PM
That's it..
Is this your car?
Do you know what antenna was used, more pictures of underneath?
Old 02-24-2020, 10:47 AM
Originally Posted by bd8134 View Post
That's it..
Is this your car?
Yeah, that’s my car under construction. I purchased the power antenna at my local O’Reilly‘s auto parts store. Nothing special. Just have to make sure that the top of the mask is flat or that you can file it flat so it matches the top of the fender. Mine is mounted in the trunk Using a mount that I fabricated.
Old 02-24-2020, 12:50 PM
Here are some pictures
Old 02-24-2020, 07:02 PM
Ah, your pictures are not showing up..
