02-26-2020, 05:41 PM
I also love my removable steering wheel
http://www.grantproducts.com/products/view/219/
Nowhere near as trick as the NRG set up though from what I can see. I take some comfort in knowing it reduces the risk of theft of my 442, but nothing can stop a flat bed tow truck (DOH). I also park way off in an empty corner of a parking lot, crank my steering all the way full left to thwart being dragged up a flat bed, and set my emergency brake. I still bite my nails when I don't see my car, and enjoy a huge sigh of relief when I come back outside to still see my car there. That constant threat of theft has drastically reduced the miles I put on my car.
If I had known that NRG also offered a removable steering wheel set up, I may have gone that direction as the Grant version has it's merits, but it's a mass produced item with a quality level of a 9 out of 10.
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
02-26-2020, 08:43 PM
Lateral-g Moderator
Yeah there’s no stopping the determined thief. I too don’t like to leave the car for long. The Grant setup works well, though I suspect that anyone that sees your shifter setup would just walk away confused.
02-26-2020, 10:32 PM
Hey wait a minute - this is YOUR post LOL
I have walked up on some people checking out my 442 and they do flip and trip over the super rare Legendary Hurst Lightning Rods along with the steering wheel removed. They want to call them Ram Rods, and some even ask if that's a Lenco? They are cool to look at and fun to occasionally play with, but the Holley Terminator EFI controlled GM Performance 4L85E does such a great job that I just plunk it into drive and have programmed it to do everything I want without having to ever really touch the shifter. I actually mostly use all of the rods just to do some occasional manual downshifts getting off the highway, or hold it in second while challenging some of the twisty winding roads around here. Once in a great while I will find myself in a street race (who, me?) That's when I use the true function of the Lightning Rods to hold each shift about 500 RPM higher than the programmed set points and bang shift my way through the pass. Funny that most also ask me if it's got the 442 engine - I usually just say yeah just to leave it be. (there is actually a '70 W30 442 455 engine in it that's been heavily massaged to 488 cubes as my little secret weapon) 8 liters is just SO much better than five. Yeah, yeah, - it's all stock LOL (until I open the remote key fob exhaust dumps right before I make a pass - that's when they know they've been had). Someday I'll get it over to a chassis dyno - 'til then, dunno, but it smokes the tires violently to all hell at a 30 roll if you just stand on it instead of easing into it... (damn ass telephone pole / ditch hunter). If any body else dare asks to drive it (like my daughter or son in law), I swap in the alternate fully castrated tune in it and they still come back all starry eyed. I wish I was over in your area and we could go see how much trouble we could get into chasing each other around, though it would probably end up with me in a ditch until I do something about my severe traction issues...
Now let's get back to your post - no hijacking!
The Following User Says Thank You to Hydratech® For This Useful Post:
02-26-2020, 11:05 PM
Lateral-g Moderator
Sounds like the car is setup right and yeah... some days there just isn’t enough tire out back. I’d probably be in the ditch right next to you  Wishing I would have tried to stuff a 315 under the back of my car. I didn’t want any rubbing issues and went conservative with a 305. Oh well. Next time.
Speaking of “spirited driving”. There’s a group out here called the breakFAST club. It’s primarily Porsche, Ferreira and other Exotics in the group but open to anyone. They invited me to an early AM run Sunday through Red Rock Canyon. Breakfast to follow. Seems like a pretty good bunch. Then again maybe they are just looking to pick on some American Muscle.  should be fun regardless.
:Captain:
02-28-2020, 05:11 PM
305 versus 315 ?
I say go run with the "imports" Sunday morning and have a blast. Since you are somewhat new to your build and vice a versa, you will be racing yourself and the road more than the other cars around you. Once you become a "Stielow behind the wheel", then you can show the import boyz how it's really done. Real cars have rock chips, but see if you can keep from eating grass, well, you say canyon which raises the stakes MUCH higher - your pilots license doesn't work in a car (DOH)  I did some Corvette canyon carving a few years ago in the mountains of Arizona and found road dust and sand to "make my heart skip a beat and also grease my seat", so let some drivers run ahead of you to see if they happen across anything before you do as an early warning. Always remember to ease into all of your maneuvers so as not to upset your chassis / traction unpredictably - brakes, steering, throttle... You may have to pull over and change your brake proportioning setting a bit too, as hot brakes in a canyon run will be completely different than most other "normal circumstances". Hmmm, sorry about rambling on about how to drive - you are just going out to have fun! Those high dollar "imports" don't want to hurt their cars either, so I'm sure you will hang with them just fine.
As far as 305 versus 315 tire tread width? 10 little millimeters? Not worth the trouble. Many don't know this, but as your tires wear, the contact patch width widens considerably. By the time you are halfway through your rear tires, they will probably measure out at 315 +/- anyway. Have you ever heard of certain class racers purposely sending their tires out to be shaved? Yep - they carefully cut more than half the tread off of a perfectly brand new tire to reduce "tread squirm", lighten up the tires for less unsprung weight, and also makes the tread area measurably wider (while still staying within the rules for their class). In your case, a few good burn outs can do this too, but spray some PAM no stick cooking oil on your rear quarter panels first and have the video camera rollin' while those dollar bills literally go up in smoke
02-29-2020, 07:01 AM
Pauls post are always a good read, reminds me of the forums in the younger days!
03-02-2020, 06:59 PM
Ok, now I can't leave it alone (really, I tried LOL)
Soooo... That 21 Pilots song (Stressed Out):
"Wish we could turn back time, to the good old days"... <-- that's what the lyrics are supposedly
... "but now we're stressed out" … "Saying, "Wake up, you need to make money"
Dunno, but every time I hear the song I swear I'm hearing "the good dope days" (Zoiks!)
Bill Clinton said he hit it a couple of times but didn't inhale (yeah right)
So today I'm listening to the radio in the shop and am now hearing "wish we could turn back time to the good post days" I know, I know...
03-03-2020, 12:49 PM
So today I'm listening to the radio in the shop and am now hearing "wish we could turn back time to the good post days" I know, I know... :lostmarble
Damn, I swear its the good dope days
03-03-2020, 08:32 PM
Interesting turn of discussion in a build post
Somehow I don't think Curtis, or anybody else for that matter, expected us to come in and toss this monkey curveball twist on page 125 of this post
Then again, it may be the best ending of a build post I've ever seen!
The Following 2 Users Say Thank You to Hydratech® For This Useful Post:
03-24-2020, 09:12 PM
Lateral-g Moderator
A lot's happened in the last few weeks for all of us. Life changing in ways that we are just starting to get a glimps of. With strange days ahead, I hope "stressed out" doesn't become a theme song for all of us.
Before all the craziness broke out, I was invited to join a group called the breakFAST club and so far, it's been a lot of fun. My first outing was a few laps through the Red Rock scenic loop. On that day we had a Lamborghini, McClaren, GT3 RS, NSX and a couple of TESLAs. Great bunch of guys and some really cool cars. It was crazy early, but we had to beat the traffic and it was worth it. Lot's of twisty sections and a few decent straight aways. Fun spirited driving, but not the kind of place anyone could really pull on me. My high speed was 103. I have to admit, it was a lot more fun than I expected and the crew didn't even bat an eye when I rolled in. Then again I don't think they expected much from me. After the drive we cruised to a local cafe for breakfast. Not a bad way to spend an early Sunday morning.
The following week I went to a meet I spotted on Instagram. It looked like all tuners, so I sent them a message and was told it was for everyone and to please come out. So I did and.... it was all Tuner cars.  Nice group and it was fun to see something different. I was surprised at the number of people taking photos with really nice cameras. Even more surprised when girls started climbing on hoods of cars! I was about to leave when I was asked if a gal could pose with my car.  I agreed, but told them no climbing on the cars. The model proceeded to tell me she would never as she love Camaro's and how she had helped her Dad restore a 70. She gave a lot of details and turned out to be a big fan of muscle cars. Have to admit I was a bit surprised. She was very respectful of the car and the pics turned out decent.
This past weekend the breakFAST club had a run around Lake Mead. Epic event! There where 20 cars, mostly Porsche and some high end ones to. I got a lot of strange looks as people arrived. I figured I'd hang at the back of the pack and see what happened. Yeah... I ended up at the front some how. I suppose that pushed me, in a good way, and everything went smooth. I even passed a few guys. I'll admit to being a bit shy in some of the tight turns, but I'm still getting used to the car in that type of driving. At one point a bunch of us got stuck behind a Motor Home and had to wait to pass. When it was finally clear and I got by, the road quickly opened up to a long straight stretch. I sucked in the lead cars a lot quicker than I expected. Just before I lifted, I glanced down and saw 132 mph. Scared me a little, but the Blonde sitting in the passenger seat seemed just fine with it.  I kept it under 120 the rest of the trip. We finished up the run with a drive down the Las Vegas Strip. Really weird to see everything shut down.
Everyone did a decent job of Social Distancing.
With all of the car gatherings cancelled till further notice, I'll probably do a few more of these. It's a good time and I have to admit I do enjoy seeing the confusion on peoples faces when I keep up with our pass them. The car has become popular and a few of the drivers are talking about getting a PT car now that they understand it.
Thanks for looking. Be safe my friends and remember.... No One is Coming, It's Up to Us.
The Following 5 Users Say Thank You to Spiffav8 For This Useful Post:
