Old 04-24-2020, 09:44 AM
syborg tt's Avatar
Just a little more of my OCD ( 01-20-20 )
TechFlex Wrap in progress
Return line - I hate this stuff (01-21-20)
Almost perfect
More blue tape with notes
On a side note I am considering having black rubber lines made with all OE fittings as it might look a little nicer.
marty-mj
Old 04-24-2020, 10:04 AM
syborg tt's Avatar
Mocking up the new Vintage Air coolant lines. (01-20-20 )
AC Lines
So I am not one for not having a washer between the nut and sheet metal. So back to Ace Hardware to get a "Machine Bushing" which I will use as a washer.
I also ordered a much thicker version from McMaster Carr for the Coolant lines as they seem to put a little more pressure on the firewall.
marty-mj
Old 04-24-2020, 10:06 AM
syborg tt's Avatar
More Parts ( 01-23-20 )
Just using these to hold wire out of the way while I am routing wires.
marty-mj
Old 04-24-2020, 10:10 AM
F'in mine's Avatar
I know its a little late but Gforce has a listing of all the critical dimensions of various transmission measurements. Hopefully you won't need them now.
https://www.crossmembers.com/blog/20...on-dimensions/
Nice shop to work on your car and bikes! Your detailing is no OCD just a high standard you go by. I guess sometimes you feel like a nut and sometimes you don't, wait that's Almond Joy not Mounds.
1969 Camaro SSRS
Simon
The Following User Says Thank You to F'in mine For This Useful Post:
syborg tt (04-24-2020)
  #1345
Old 04-24-2020, 10:14 AM
syborg tt's Avatar
Mocking Up some of the new Parts ( 01-24-20 )
Not a fan of how tight this line fits. It's like the line is about an inch to short. So this is going in the garbage and I will have to make a new line.
Eventually I will build a Carbon Fiber Intake tube.
marty-mj
Old 04-24-2020, 10:16 AM
syborg tt's Avatar
Thank you for the link as I really could of used it instead of taking everyone's word.
On a side note I am kinda "Mounds" guy as I love dark chocolate. Of course as you can see I am a little bit nutty.
marty-mj
Old 04-24-2020, 10:50 AM
syborg tt's Avatar
Laying out the Holley Terminator X Engine Harness. (01-26-20)
I was a little board and didn't really feel like working on the car and I really wanted to ride but the weather sucked and the trails were closed. SO I put the bike rack back on the car.
Since my drivers door hinges is a little worn I figured this would be the best time to replace the hinges. So I put a small order together.
After looking at this picture it looks like I might have a problem.
marty-mj
Old 04-24-2020, 10:53 AM
syborg tt's Avatar
Cleaning up the wire harness's (01-26-20)
I love these velcro strips as it makes storing stuff neatly very easy.
marty-mj
Old 04-24-2020, 10:56 AM
syborg tt's Avatar
I finally found the correct Temp Coolant Switch that plugs into the Holley EFI (01-29-20)
Not sure why I did this but many years ago someone taught me how to make hose clamps round again. It's pretty simple just tighten them around a socket and come back in about 5 minutes and they are round again.
Yep, More blue tape and this one has a reminder on it.
marty-mj
Roscoe03 (04-24-2020)
  #1350
Old 04-24-2020, 11:47 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Is this a street car only? I ask because I know its really easy to boil power steering fluid during track days or autocross. A cooler would be a good idea in any case. I like the machine bushing idea for washers, I'm going to have to remember that.
Instagram- camaroaj
The Following User Says Thank You to CamaroAJ For This Useful Post:
