Old 05-04-2020, 08:37 PM
WILWAXU WILWAXU is offline
Thumbs up
Great updates and that is the steering wheel that I want for my car.
Thanks! I was actually looking for a montecarlo and liked the feel of this one.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
The Following User Says Thank You to WILWAXU For This Useful Post:
syborg tt (05-12-2020)
  #72
Old 05-04-2020, 08:52 PM
Thumbs up
Spent Sunday morning on my back Routing the (Hot Rod Fuel Hose) fuel line, looking at it.. adjusting, looking, adjusting, repeat, etc. Once I had the layout, I put the ends on and hung it in place. Finally got the fittings to finish up the brake lines.
Today after work (from home) I mocked up the ac compressor and alternator. Liking the blacked out look. Then got to work and knocked out the power steering high pressure hose (Earls) and buttoned up a few hold downs for the brake lines.
After doing PTFE and then high pressure AN lines.. my hands are very sore
All in all, I feel I've made good use of my "quarantine" time so far
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
The Following 2 Users Say Thank You to WILWAXU For This Useful Post:
fleet (05-05-2020), syborg tt (05-08-2020)
  #73
Old 05-07-2020, 08:28 PM
Talking
The current Nova Vintage Air kit calls for the mounting plate to be bolted on the outside of the firewall... which if it covered all the sins would be good.. but not the case on this car. Plus, I'd rather use the DSE cover I already have. Solution, move the mount plate inside
Still tinkering with the shifter hump. Really waiting on my welder (electrical) connection to be finished to move forward with this and a few other small projects.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
  #74
Old 05-08-2020, 09:24 PM
Talking
Spent the day cleaning up the A/C mount plate and permanently making it part of the car. The firewall side will get some work later when I weld the cover plate on. Hung the A/C unit and drilled the final mounting holes. Closed out the day laying down sound deadener.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
  #75
Old 05-10-2020, 04:32 AM
fleet's Avatar
fleet fleet is offline
Nice progress John...
I just followed you on IG...I hope that’s wise.
Seriously though, enjoying your pics.
The Following User Says Thank You to fleet For This Useful Post:
WILWAXU (05-10-2020)
  #76
Old 05-10-2020, 06:13 AM
Thumbs up
Thanks for the follow! Only wise if you like a wide range of cars
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 05-10-2020, 07:40 AM
fleet's Avatar
I do!
Btw-I may have missed it earlier in your thread John...how do you plan to use the Nova?
Old 05-10-2020, 08:03 AM
Thumbs up
I do!
Skip,
The Nova will be my car for local vintage car events, Goodguys, GNRS, etc..., and if things go as planned, my ride on the Hot Rod Power Tour in 2021 and beyond. I usually drive my cars out from California to the Tour (7k+miles).. so I need a solid, reliable, and comfortable car.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
fleet (05-10-2020)
  #79
Old 05-12-2020, 06:40 AM
BigBronco's Avatar
BigBronco BigBronco is offline
Skip,
I will have to get a copy of what all you did with the A/C as I am basically going to be doing the same exact thing. Probably the one item I have not touched with the car.
Setup is looking great! I have been busy doing a suspension changeout on my Wife's Firebird, otherwise, I would have been tidying up everything on the Nova currently.
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
The Following User Says Thank You to BigBronco For This Useful Post:
WILWAXU (05-12-2020)
  #80
Old 05-17-2020, 08:24 PM
Wink
Not much for pictures over the past week, mostly fitting things, planning out the engine wiring harness, etc..
Today I did a very scary thing.. I cut a near 50 y/o dash
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
syborg tt (05-18-2020)
