Old 05-25-2020, 03:25 PM
jmac jmac is online now
No you didn't!
My 1967 Camaro
Old 05-25-2020, 03:43 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by jmac View Post
No you didn't!
No it is primer
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
syborg tt (05-29-2020), will69camaro (05-25-2020)
  #393
Old 05-25-2020, 04:56 PM
colorado80439 colorado80439 is offline
Well if you're going chalk, you might as well go matte
I'm still voting for Hugger
https://hot-cars.org/2017/05/25/hugg...new-zl1-motor/
Old 05-25-2020, 09:26 PM
No it is primer
Old 05-26-2020, 08:51 AM
SSLance's Avatar
SSLance SSLance is offline
No it is primer
Lance
Old 05-26-2020, 09:32 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default GW's 40
Porsche Calk White ?
Same color as GW's 40 right?
Sure miss him...
Ty Ingle, USAF Retired
FREEDOMBIRD
The Following User Says Thank You to OLDFLM For This Useful Post:
ScotI (05-26-2020)
  #397
Old 05-26-2020, 12:50 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Mark, do you run an expansion tank on the LT4 / LT5 swaps?? If so, what tank has worked for you?
TIA.
Old 05-26-2020, 02:36 PM
Stielow's Avatar
TIA.
For the radiator and the intercooler system I do not run an overflow tank. The radiator has a small amount of air in it for expansion I do run an overflow tank. Not sure the brand. What ever will package. No tank for the intercooler system.
Mark
Stielow Engineering
Old 06-03-2020, 09:33 AM
DKz Garage's Avatar
Mark... I know you run a dry sump in your cars.....As these supercharged motors create a lot of heat - Do you run an external oil cooler, if so, where do you mount it?? TIA
Sorry to be "that guy" with all the questions
Old 06-03-2020, 09:54 AM
Stielow's Avatar
Default Camaro LT5
It is built into the end tank of the C&R radiator. Oil to water heat exchanger.
Works great.
I also use a oil adaptor with a built in thermostat. Improved Racing makes one as well as Holley.
Stielow Engineering
fleetus macmullitz (02-25-2023), jmac (06-03-2020)
