Old 06-11-2020, 04:31 PM
WSSix WSSix is online now
It's definitely a time consuming task if you're not well versed in it. And you're correct, you can always take it apart and do it again if it's noisy. So long as it spins properly now and everything is tight when you go to drive, the worst it could do is make noise. Good luck, Miles.
