Old 03-11-2020, 04:01 AM
dhutton dhutton is offline
Have you used one of the DCC controllers Don ? Did it work well?
I have used it a couple of times. Works great.
The Following 2 Users Say Thank You to dhutton For This Useful Post:
214Chevy (03-21-2020), waynieZ (03-11-2020)
  #512
Old 03-11-2020, 04:03 AM
Originally Posted by 65 Drop Top View Post
Got it, thank you. What I didn’t realize was that the DCC and the GMPP ECM do not hook up together. Are there any potential issues if the ECM does not know what the fans are doing? And then do you just abandon the GMPP fan wire?
I just left the GMPP fan wire unused. No issues. ECM only cares about coolant temperature.
65 Drop Top (03-11-2020)
  #513
Old 03-21-2020, 05:20 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Thanks for all of your insight Don.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-22-2020, 10:18 AM
NAPA 68 NAPA 68 is offline
Looking at the DCC controller and reading the instructions, it appears to me the fan will continue to run after the car is shut off. First, am I correct? Secondly, is there a right way to get around it?
In advance, thanks for your consideration.
Tim
Old 03-22-2020, 11:00 AM
Tim
It only runs for a few seconds until the coolant in the radiator falls below the set temperature. Not a big deal in my experience.
214Chevy (03-22-2020), NAPA 68 (03-22-2020)
  #516
Old 03-27-2020, 10:13 AM
billohio billohio is offline
I saw the 3 different sized DCC controllers. Which one would be needed with an Entrophy dual fan radiator? There's an FK45, 75 and 95.
Old 03-27-2020, 01:39 PM
I just use the 95 since I’m guessing the extra margin can’t hurt.
billohio (03-27-2020)
  #518
Old 07-06-2020, 07:42 PM
andrewb70's Avatar
Default C7 Corvette fan
With my urging, one of my tuning customers installed a C7 Corvette fan in his 408 Windsor powered Ford F150 with the Holley Dominator ECU.
This fan works flawlessly with the Holley Dominator, which means it will work perfectly with all other Holley systems (excluding Sniper). Fan control was integrated with the AC system trinary switch, which enables different fan speed settings regardless of engine temperature.
He had his truck idling with the AC on in 95 degree AZ heat and the temperature never went above 186, with the fan hovering around 50-55% duty cycle.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (07-07-2020), dhutton (07-07-2020)
  #519
Old 07-07-2020, 10:03 AM
dontlifttoshift's Avatar
Derp. That's a pretty easy way to do it. 12v from trinary = fan runs at XX%
Well done.
And yeah, just did a C7 fan with a Terminator in a 55 Pickup and its awesome.
Donny
Old 07-07-2020, 10:44 AM
andrewb70's Avatar
Well done.
Donny,
Give me a call when you get a chance. I think you have my number. If not, check your PM.
Andrew
Instagram @dr__efi
My YouTube Channel
