Old 09-08-2020, 12:24 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by ArisESQ View Post
Just wondering - have you mentioned what gear ratios your going with on this one? Any info on the third member you selected?
Thanks again!
I’m running a 3.50 ratio with a Tremec Magnum with a 2.66 first gear. I ran a similar set up with my LT4 and it worked well.
The 3rd member is a GearFX Ford 9 inch the Ford gear is micropolished and run in on their dyno. If you can find a real Ford gear I’ve had the best luck with them for noise.
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (09-08-2020), kwhizz (09-10-2020), Sonar Chief (09-08-2020)
