Old 09-08-2020, 01:46 PM
Stielow's Avatar
Stielow Stielow is offline
It is going back together. It will come back to my shop for the final wiring.
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
camcojb (09-08-2020), fleetus macmullitz (09-08-2020), kwhizz (09-10-2020), Sonar Chief (09-08-2020), WILWAXU (09-09-2020)
  #482
Old 09-09-2020, 08:56 PM
randy randy is offline
With the ecu up front where do you route the wires to go behind the engine? I wanted to do that with my gmpp controller but the wires weren’t long enough to put behind the firewall with the ecu and fuse box up on the core support
Old 09-10-2020, 03:59 AM
Stielow's Avatar
I extended the wires. Approximately a 100 of them. Well that is what it seemed like.
Mark
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
camcojb (09-10-2020), EVIL SS (09-10-2020)
  #484
Old 09-10-2020, 04:08 AM
Stielow's Avatar
Mark
Stielow Engineering
Old 09-10-2020, 06:49 AM
Stielow's Avatar
Default Camaro LT5
Corvette C6 ZR1 caliper with a Gen 6 Camaro ZL1 rotor with a custom hat made. The iron rotors have a better thermal properties compact to the Carbon Ceramics. Also the Delphi ABS will work better with iron rotors over the Carbons. I used the Bosch ABS on the last cars with Carbon Brakes.
Stielow Engineering
Old 09-10-2020, 07:32 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Is it possible to get a set of those rotor hats? I have C6 ZR1 brakes and would like to be able to put iron rotors on it for track days.
Instagram- camaroaj
Old 09-10-2020, 07:58 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default Bigger Pics?
Any chance we can get the pics enlarged in the thread?
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 09-10-2020, 08:01 AM
Stielow's Avatar
Jeesh... Lillard complained they were too big
Stielow Engineering
OLDFLM (09-10-2020)
  #489
Old 09-10-2020, 10:02 AM
Stielow's Avatar
Which ones do you want?
Stielow Engineering
Old 09-10-2020, 10:10 AM
camcojb camcojb is online now
Since when do you listen to Charley?
