Old 10-08-2020, 08:07 PM
akrapovic's Avatar
akrapovic akrapovic is offline
Default DSE control arms 1st gen camaro with ATS afx spindles
Need some help. I have a 69 camaro with stock subframe, dse control arms and ats afx tall spindles. I'm at the point where I'm going to get an alignment. Which alignment specs would/ should i follow? DSE or ATS/speedtech.
Im a suspension newb so I realize this may be a dumb question. Regardless, thanks for the help.
Marcus
Old 10-08-2020, 08:44 PM
68LS1's Avatar
68LS1 68LS1 is offline
I run same set up, DSE upper arms and tall spindle. We have mine set up at
Caster 5 degrees
Camber -0.5
Toe in 1/16 total
Drives nice and straight
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 10-08-2020, 08:57 PM
akrapovic's Avatar
Caster 5 degrees
Camber -0.5
Toe in 1/16 total
Did you setup for track or are these specs intended for more of a street car. I'm looking for street setup.
Also thanks for the info.
Old 10-08-2020, 09:41 PM
Musclerodz's Avatar
Those numbers work good on street. Its basically the same numbers I use.
Mike Redpath
Musclerodz & Customz
facebook page
Old 10-09-2020, 12:04 AM
Beechy's Avatar
Beechy Beechy is offline
Great advice from both 68LS1 and Musclerodz......go with those numbers.
FWIW.....I have run more caster (7 or8) but had to back it down to 5 cos understeer in the wet.
Jim Grant
Melbourne, Australia
(Dual citizen)
Old 10-09-2020, 07:06 AM
68LS1's Avatar
For the street, it is pretty fun through local twisty roads
Roger
Old 10-09-2020, 01:49 PM
akrapovic's Avatar
Thank you so much guys. Im going to give those specs a shot
