Old 09-10-2020, 12:31 AM
AMSOILGUY's Avatar
AMSOILGUY AMSOILGUY is offline
Default Centerlink fitment question
Can anybody tell me if the centerlink on a 1969 camaro is the same for SB and BB? My camaro has a 502 which the centerlink has been hitting the oil pan for what appears to be a long time. Is there options out there that would aide in giving me a little bit more clearance so I can get the wheels to turn lock to lock? Thanks
[email protected]
www.jacobehlers.com
Old 09-11-2020, 12:14 AM
camcojb camcojb is online now
They made a small one (1" diameter or so) for manual steering and 1.125" for ps and BB. But I believe they're interchangeable. The thing with big blocks is they can be bolted in on the small block pads/mounts, or the correct bb mounts/frame pads.
The factory BB frame pads move the engine slightly forward and offset to the passenger side. But even in this config the center link should clear as long as it has the correct oil pan.
Old 09-11-2020, 11:33 AM
AMSOILGUY's Avatar
Thanks Jody. This could open a whole can of worms.
[email protected]
www.jacobehlers.com
Old 10-12-2020, 07:41 PM
David Pozzi's Avatar
The larger diameter center link appeared in 1969. I used to think it was stronger/stiffer and perhaps a big block component. I finally got my hands on one and needed to do some modifications to it so I ground on it and found it was very soft! I think some were needed quickly and GM made a version that was larger diameter out of softer steel and did not heat treat them. I doubt they are any better than the smaller one which I think is 7/8" or 15/16".
http://www.PozziRacing.com
The Following User Says Thank You to David Pozzi For This Useful Post:
AMSOILGUY (10-13-2020)
Old 10-12-2020, 09:31 PM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
The 502 comes with a truck pan which will hit the center link.
You will need this pan kit from GM:
12495360
4-Quart Oil Pan, Gen-V and Gen-VI
The Following 2 Users Say Thank You to zz430droptop67rs For This Useful Post:
AMSOILGUY (10-13-2020), redfire69 (10-15-2020)
Old 10-12-2020, 10:08 PM
AMSOILGUY's Avatar
I don't want to reduce the oil capacity really. That would be a great fix I just don't know if that's the answer?
[email protected]
www.jacobehlers.com
Old 10-14-2020, 09:41 PM
AMSOILGUY's Avatar
12495360
I found this disclaimer associated with this pan:NOTE: Not intended for competition or spirited street driving. Oil sump capacity is insufficient for performance driving. Oil system starvation may result from expended high-rpm operation, hard cornering or rapid acceleration.
I guess its only suitable for a trailer queen.
[email protected]
www.jacobehlers.com
The Following User Says Thank You to AMSOILGUY For This Useful Post:
zz430droptop67rs (10-15-2020)
Old 10-15-2020, 06:19 AM
Yes, I saw where they recently added that disclaimer. Another option would be one of the aftermarket pans with more capacity using kick-outs, but still clears the center link.
I've installed 2 ZZ502's in 1st gens using the above pan. Obviously with the filter I had 5 quarts.
Never had that problem, but somebody must have. I did experience unusual oil consumption, but that was traced to poor oil ring sealing and valve guide seals. I understand that has been corrected on the later motors.
The Following User Says Thank You to zz430droptop67rs For This Useful Post:
Old 10-15-2020, 06:35 AM
andrewb70's Avatar
I do believe that either Moroso or Milodon, or maybe both, make a Gen 6 BBC oilpan that will fit the Camaro chassis better AND provide the desired capacity and baffling.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
