Old 12-06-2006, 12:56 PM
Damn True's Avatar
Damn True Damn True is offline
So will there be a new version with the coilover setup? Will there be a price delta between it and the current setup with the Afco-type adjusters?
Ty?
Old 12-07-2006, 03:20 PM
How did I miss this one?
Yes we are offering a new front suspension package called the Chicane-LM. this kit will include the following items:
Global West tubular upper control arms with ball joints and Del-a-lum bushings
Global West lower control arms for coil over with ball joints and Del-a-lum bushings
Tall AFX spindles with C5 hubs and hardware
Hotchkis hollow 1-1/8" front sway bar
Moog inner tie rod ends (pair)
Moog idler arm
Moog pitman arm for P/S
Baer tracker adjustable outer tie rod ends with sleeves
Lee built P/S box
Rag joint for P/S box
Chicane-LM coil over weld in brackets
Bilstein aluminum coil over shocks (pair)
Hyperco coil psrings (pair)
Global West solid body bushings
ATS grae 8 front end hardware kit
Retail pricing on this will be $4500.00, but we will offer it at an introductory rate of $4200.
Tyler
Old 12-07-2006, 04:23 PM
olds87 olds87 is offline
Is this suspension kit only for 1st gen camaros, and later on would kits be offered for others body type (G-body, A-body cars)?
James W.
1987 Oldsmobile
Cutlass Supreme
Old 12-07-2006, 05:49 PM
67bird 67bird is offline
Default What is Chicane-LM complete front suspension kit??
Tyler,
Will the kit items be avalible individually? I already have DSE body bushings, and I have a special rag-joint for my Ididit column, so I won't need the items in the kit. Also, when can we start ordering?
Ben Mowery
Old 12-08-2006, 11:31 AM
The kit is for F/X body cars only at this time, but if there are enough inquiries for one, we'll put it together.
Ben-
You can delete any itmes you don't need out of the kit.
Tyler
Old 12-08-2006, 11:32 AM
DOUBLE POST!!!!!
Old 12-08-2006, 11:42 AM
Damn True's Avatar
The splined sway-bar didn't make the cut?
Old 12-11-2006, 03:00 AM
Kinda wondered the same thing, what happened to the splined sway-bar? I am glad someone else is coming out with a kit. Competition is the greatest thing for the market.
