12-02-2020, 01:43 AM
Rear Suspension install
Started installing some of the rear suspension components. I was going to polish the Heidts aluminum center section, but it was recommended to just do "chrome" powder coating. Sadly, that didn't turn out so well, but I'll live with it. Not really going to show under the car anyway. The powder coater felt really bad about it. He said it might happen (gassing). He cooked it in the oven for 5 hours, hoping to get the impurities out of it, but it still pitted. Just cheap dirty casting from the mfg. Nothing he could do. Only charged me $100, instead of the original $200 quote. I can't fault him, he tried. Even put several hours of prep into it before hand, to smooth it out.
Before
After
Other stuff going in
$500 doesn't buy much in the quality paint scene these days. The color I chose is up to $880 a gallon. I bought it a year ago for $600 a gallon. This is 2 quarts of jet black, 1 quart of black primer, and 1 gallon of clear, and the catalysts to go with them
The Following User Says Thank You to Rodknock For This Useful Post:
12-02-2020, 02:51 AM
Lateral-g Moderator
Before
After
It works.
The Following User Says Thank You to Spiffav8 For This Useful Post:
12-02-2020, 08:21 AM
Originally Posted by Spiffav8
It works.
Yup!! If I was building a show car, it would be a different story, but for a driver, it's good enough. Mainly wanted protection from the elements.
The Following 2 Users Say Thank You to Rodknock For This Useful Post:
12-02-2020, 11:26 AM
Lateral-g Moderator
Powder coating holds up really well. I'm glad I used it on my AME frame, rear suspension an diff. Also super easy to clean and keep looking nice. I think it's the smart move.
12-02-2020, 11:51 AM
I agree 100%
12-03-2020, 05:04 PM
looking good, you work really fast
The French Frog
The Following User Says Thank You to streetbird For This Useful Post:
12-04-2020, 01:38 AM
8 years into a 2 year project, doesn't seem too fast to me
12-04-2020, 02:28 AM
Got just a little bit more done before I got called to work. Was expecting to do more, but a plumbing leak at home, and getting called to work 11 hours earlier than expected, sorta changed things.
Got the third member installed into the housing, and got it all bolted up. Started installing the stub shafts, but that's as far as I got. I realized, after moving 3 different times, since I bought all this stuff, I am missing some hardware.
Don't have a brake caliper mounting bolts. Not sure what happened with those, so I'll have to find some.
Tried putting that heavy ass iron third member in with the housing in place...that's a negative ghost rider
This'll work
There it is
Just swing it up into place
The Following 4 Users Say Thank You to Rodknock For This Useful Post:
12-09-2020, 09:17 AM
Wheel Studs
12-09-2020, 09:25 AM
Rear Suspension going in
