Old 12-12-2020, 08:27 AM
bkswede bkswede is offline
Hey Marty,
Thanks for the detailed update and the progress looks great! Look forward to future updates,
Brian
Sent from my iPad using Tapatalk
63 Chevy II - Build in Progress
2017 Camaro ZL1
2010 Mercedes C63 AMG
The Following User Says Thank You to bkswede For This Useful Post:
syborg tt (12-12-2020)
  #1482
Old 12-14-2020, 06:26 PM
syborg tt's Avatar
Default Wiring, Wiring & more Wiring - The Clean Up ((09-07-20 )) Part 2
So how is it possible that I used all of these tools.
Moving to my next project.
I don't have many wires that I want to label so as much as I want the really nice label maker I am going to do it the poor
man way. So off to Office Depot to Dymo Label maker for $40.00 and some clear heat shrink tubing.
So here is my first try and I think it worked good enough for my little project.
Sometime I wish I had a 3rd arm to help hold wires while I am soldering.
marty-mj
The Following 6 Users Say Thank You to syborg tt For This Useful Post:
camcojb (12-15-2020), Damerjo (12-16-2020), fleet (12-14-2020), jarhead (12-15-2020), Ricochet (12-15-2020), WILWAXU (12-14-2020)
  #1483
Old 12-14-2020, 07:44 PM
WILWAXU WILWAXU is offline
Talking
My Dymo uses heat sensitive label material, they turn black when heated.. found out the hard way
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 12-14-2020, 08:43 PM
syborg tt's Avatar
Default 2nd Chance Camaro - Let the Project Begin
Well it looks like I am going to do some testing with a hair dryer. Not sure how much of and issue it will be on the inside of the car. More worried about the stuff in the inner fender.
Edit
I did use a heat gun to shrink the heat shrink tubing. What’s your thoughts ??
marty-mj
Old 12-15-2020, 02:27 AM
69hugger's Avatar
69hugger 69hugger is offline
Marty,
Can you tell us where you got that clear heat shrink assortment?
Thanks in advance.
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 12-15-2020, 07:49 AM
syborg tt's Avatar
Originally Posted by 69hugger View Post
Marty,
Thanks in advance.
Hi Bill.
Sure not a problem
XHF 160 PCS 3/32" 1/8" 3/16" 1/4" 5/16" 3/8" Clear 3:1 Waterproof Automotive Electrical Heat Shrink Tubing Assortmen Kit Marine Grade Adhesive Lined Tube, Insulation Sealing Oil-Proof Wear-Resistant
https://www.amazon.com/160-pcs-kit%E...P3E6A70&dchild
marty-mj
69hugger (12-15-2020), Damerjo (12-16-2020)
  #1487
Old 12-15-2020, 02:25 PM
syborg tt's Avatar
Default Hella Horns - Gotta Have Them (( 09-12-20 ))
One thing that I really wanted was a nice loud set of horns and I am pretty confident these will work just fine.
Hella Part # 011225802 $12.83
marty-mj
fleet (12-16-2020)
  #1488
Old 12-15-2020, 02:33 PM
syborg tt's Avatar
Default Holley EFI Relays - Weld Studs (( 09-13-20 )
One of the benefits of the DEI X-Mat is you can push the weld studs into and make a perfect circle. I will be mounting the Holley Relays to these studs.
It's important that you remove all the paint before you bond them.
marty-mj
Old 12-15-2020, 02:43 PM
syborg tt's Avatar
Default Organizing my mess (( 09-15-20 ))
Not only do I take a lot of notes I do my best to keep them very organized so I can find things when I need them.
More parts showing up daily ( Thankfully I ship everything to work. )
marty-mj
Old 12-16-2020, 03:51 PM
syborg tt's Avatar
Default Holley EFI Tank (( 09-17-20 ))
It's time to put the tank together and it was a very nice day to be out in the garage.
Pieces & Parts
Time to build the the fuel pump/fuel level assembly.
You may have to move the wires over a little bit so make sure you look.
Very important note here. Make sure you cover the hole for the float. Because if it can happen it will happen.
Just in case you wanted to know yes I dropped a bolt inside the tank. Ugh !!!
The float assembly ready to drop in after it was modified per the instructions.
Remove the access off the bottom.
Make sure you line up the gasket correctly.
Call your daughter and ask her to help you pack it up and put it back in the box.
marty-mj
fleet (12-16-2020)
