Old 12-16-2020, 03:51 PM
syborg tt's Avatar
Default Holley EFI Tank (( 09-17-20 ))
It's time to put the tank together and it was a very nice day to be out in the garage.
Pieces & Parts
Time to build the the fuel pump/fuel level assembly.
You may have to move the wires over a little bit so make sure you look.
Very important note here. Make sure you cover the hole for the float. Because if it can happen it will happen.
Just in case you wanted to know yes I dropped a bolt inside the tank. Ugh !!!
The float assembly ready to drop in after it was modified per the instructions.
Remove the access off the bottom.
Make sure you line up the gasket correctly.
Call your daughter and ask her to help you pack it up and put it back in the box.
marty-mj
fleetus macmullitz (12-16-2020)
