Old 12-17-2020, 03:58 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Default Chris's 66 Chevelle upgrade
A little past history on this car....... I bought it back in 2005 and did the Body and Paint, suspension, brakes, and added a 406 small block and 700R4 trans....... Great car... Took it on it's first of many Power Tour Long Haul's in 2006..... My son Chris got the car in 2010 and continued the tradition of driving on the Road Tours
So...... Fast forward to 2020 and we did the 1st Barrett-Jackson Road Tour and I was driving my LSA powered 66 Chevelle (just turned 34,000 trouble free miles) and Chris had the 406 powered car........ After driving and comparing the differences I finally convinced him to swap out the Old School to Modern Technology ......and so it starts..... LOL...... Bought a LS 3 connect and cruise 4L70E set-up, Ricks Tank with a Vaporworx fuel pressure set-up, adding a HydraBoost, Dakota Digital Dash and controllers, also a Holley mid mount front drive assy to clean things up, and a Hooker LS mounting kit.......
Here we go !!!!
The Following 7 Users Say Thank You to kwhizz For This Useful Post:
ADY (12-17-2020), camcojb (12-17-2020), Roger M (12-17-2020), Sonar Chief (12-21-2020), syborg tt (12-17-2020), waynieZ (12-19-2020), WILWAXU (12-17-2020)
Old 12-17-2020, 05:37 AM
bkswede bkswede is offline
That’s awesome - look forward to following along as you upgrade. You’re making some really nice improvements which will make the car so much more reliable and easier to drive... that said, looks like the 406 did pretty well for itself, too, with all the tours you and your son have taken with it.
63 Chevy II - Build in Progress
2017 Camaro ZL1
2010 Mercedes C63 AMG
The Following User Says Thank You to bkswede For This Useful Post:
kwhizz (12-17-2020)
Old 12-17-2020, 05:06 PM
Blackhawk's Avatar
Blackhawk Blackhawk is offline
Wow 34k miles and that many PT long hauls is really cool to see, looking forward to how this one comes along.
Old 12-17-2020, 05:41 PM
64G-lark's Avatar
64G-lark 64G-lark is offline
Looking forward to following the build.
Old 12-17-2020, 05:54 PM
syborg tt's Avatar
Subscribed.
Looking forward to this build.
marty-mj
Old 12-18-2020, 03:34 AM
kwhizz's Avatar
Got the Holley 302-3 oil pan installed...... also the Holley mid mount front drive assy.....the Holley / Hooker forward bias engine mounts arrived and were installed....
The Following User Says Thank You to kwhizz For This Useful Post:
syborg tt (12-29-2020)
Old 12-18-2020, 03:41 AM
kwhizz's Avatar
Also the Rick's Tank and Carls Vaporworx PWM fuel pressure control system are here.......
Old 12-18-2020, 03:55 AM
kwhizz's Avatar
Included in the Holley / Hooker install kit is the transmission crossmember...... Boy.....30 minutes and it was done....what a treat to get something that actually fits as it should..... there are two mounting plates that bolt right into the existing frame holes ..... bolt it in and drill two hole thru the side frame, bolt it in and you are done......And the side mounts have all the various mounting holes designed in to accommodate all transmission variations ......
The Following 4 Users Say Thank You to kwhizz For This Useful Post:
syborg tt (12-29-2020), VITO444 (12-24-2020), waynieZ (12-19-2020), WILWAXU (12-18-2020)
Old 12-19-2020, 11:19 AM
Nice setup. Subscribed.
Old 12-19-2020, 11:23 AM
warhawkchevelle warhawkchevelle is offline
Very cool! Looking forward to see the progress!
