Old 03-30-2021, 07:56 AM
cabudge09 cabudge09 is offline
Some progress on the dry sump/oil cooer setup. The oil should have no problem staying cool on this car. I was debating whether or not it needed a cooler because of the dry sump system. The oil will cool as it's routed to the dry sump tank and back to the engine. The dry sump tank is also mounted up front behind the passenger headlight so it will get plenty of airflow.
My biggest concern for cooling is the TKX transmission. Do you think I should install a trans cooler? The car will see 20-30 minute track sessions, mostly HPDE stuff initially. My second concern was the rear differential. I think we are just going to run a trunk mounted catch can as a starter and go from there.
The Following User Says Thank You to cabudge09 For This Useful Post:
andrewb70 (03-31-2021)
