Old 04-16-2021, 06:21 AM
Jay Hilliard's Avatar
Default trunk drop off panel replacement question
Is it possible to replace trunk drop offs on 69 camaro without removing quarter panel?
Jay
Old 04-16-2021, 06:36 AM
dhutton dhutton is offline
It is but it will take some time and patience. If they are not completely shot it might be easier to section in pieces of the replacement. Hopefully the car is not in final paint.
Old 04-16-2021, 07:20 AM
Thanks Don. Just got car blasted and found this issue. Quarters are good. I will try to section them as you stated if possible.
Jay
Old 04-16-2021, 11:24 AM
Using an air file to grind away the spot welds will avoid trying to drill them out where access is limited. Doesn’t damage the panel you are keeping either.
Jay Hilliard (04-17-2021)
Old 04-16-2021, 04:07 PM
TechNova TechNova is offline
IF used properly. It is very easy for beginners to do it wrong and end up with a divot in the bottom panel. It needs to be done carefully.
Old 04-16-2021, 05:40 PM
I watch the color. When it turns blue the metal is paper thin.
Old 04-18-2021, 06:21 AM
Frankenstine's Avatar
Frankenstine Frankenstine is offline
Default Hi Jay
Jay, does this mean you have started on your car ?????
Kieth
Old 04-18-2021, 06:52 PM
Hey Keith,
Yes I have. Hope you are doing well.
Jay
Old 04-19-2021, 06:30 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Hey Keith,
Pictures man...pictures.
Curtis
