Old 05-24-2021, 12:54 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by cpd004 View Post
I'm sure it may be still early to tell, but we've had a few 80+ degree days, so wondering how the fuel tank system is working out as far as smell/expansion, etc.?
My tank set up worked with no issues.
Stielow Engineering
cpd004 (05-24-2021)
  #842
Old 05-24-2021, 12:57 PM
Stielow's Avatar
Originally Posted by EVIL SS View Post
Mark, what is this?
It is a power steering fluid filter. Good idea that did not work. I removed the filter cartridge and left the can to keep the hoses the same.
Might of been too fine of a mesh.
Mark
Stielow Engineering
fleetus macmullitz (05-24-2021)
  #843
Old 05-24-2021, 12:58 PM
EVIL SS EVIL SS is offline
Mark
Got it, thanks! Car came out great!! Thanks for sharing!
Old 05-27-2021, 04:43 AM
srode1 srode1 is offline
You used 2 intercooler pumps but one intercooler radiator . The LT5 ZR1 has two intercoolers which are smaller which is why there are 2 pumps in it I would guess. With one intercooler in your car, do you use 2 pumps to increase the flow and improve cooling or to help make sure both sides have equal flow? I ask because the crate engine controller is set up for one pump, the ZL1 pump from what I can glean from the documentation.
Did you run both your pumps off the factory harness by tapping into it and adding a plug for the 2nd pump?
Old 05-27-2021, 05:40 AM
Stielow's Avatar
I added 2 nd pump because my engine makes over 900 HP. I reworked the wiring in the fuse box and up gauged the wiring to run 2 pumps.
The team that did the create engine development claim one pump is good. I used 2 like the stock ZR1.
Mark
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
ADY (05-27-2021), fleetus macmullitz (05-27-2021), srode1 (05-27-2021)
  #846
Old 06-01-2021, 11:20 PM
camcojb camcojb is online now
Like this one ?
So do I need to make a new page on Stielow Engineering?
The Following 3 Users Say Thank You to camcojb For This Useful Post:
dhutton (06-02-2021), waynieZ (06-09-2021), WILWAXU (06-04-2021)
  #847
Old 06-02-2021, 07:09 AM
clill's Avatar
clill clill is offline
Apparently
The Following 7 Users Say Thank You to clill For This Useful Post:
Boris632 (06-17-2021), camcojb (06-02-2021), EVIL SS (06-02-2021), Ketzer (06-02-2021), Spiffav8 (06-02-2021), waynieZ (06-09-2021), WILWAXU (06-04-2021)
  #848
Old 06-02-2021, 09:40 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Apparently
Approved. This should be fun to watch.
Curtis
Old 06-02-2021, 12:36 PM
jeff71 jeff71 is online now
If that was an even trade for Apex I would say mark won that deal. Because nobody likes a white 69 Camaro except Charlie.......
The Following User Says Thank You to jeff71 For This Useful Post:
clill (06-02-2021)
  #850
Old 06-02-2021, 01:40 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Apparently
This is very awesomesauce....
