Old 12-26-2020, 09:24 AM
69Toronto 69Toronto is offline
Smile
Originally Posted by CamaroAJ View Post
I had to work Saturday so I didn't get to work on the car. During the week though I got the wicker bill rough cut, hand filed, and mocked up on the car. I'm thinking about making this out of carbon fiber as well and selling some to recoup car part funds.
Id take a carbon wicker bill too
Old 12-26-2020, 11:51 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Originally Posted by 69Toronto View Post
Are those anvil front fenders?
Look incredible....curious if they fit pretty good out of the box?
thanks
bob
They fit ok. They need work by the windshield and door to fit better. Around the grille and lower valance fit pretty well.
Working on the carbon wicker bills already. Made a test panel to see how well it worked and should have a few ready in February.
Instagram- camaroaj
The Following User Says Thank You to CamaroAJ For This Useful Post:
syborg tt (12-27-2020)
  #473
Old 12-27-2020, 07:53 AM
Im going to msg you on instagram: pro_touring69.toronto
Old 02-14-2021, 10:40 PM
CamaroAJ's Avatar
So we're back with work on the Camaro. Well, except this weekend because it was too cold in the shop. The new shop I'm working for is D Built Hotrods. Give us a follow on Facebook or Instagram. Dbuilt.hotrods on Insta and I think its the same on Facebook. CamaroAJ is my personal one where I post the car up.
Anyways I got the car racked up and to work. Last time I worked on the car I made temp brackets because I didn't have any steel to make solid enough brackets to hold things where they needed to be.
With the new brackets made the wheel clears at full lock at ride height. I still have offset upper control arm bushings to install to move the wheel in and get a bit more clearance. Then I use zip screws to hold everything together and sanded the fender to get everything bonded back together.
With the passenger fender ready to bond I test fit the carbon fiber trans tunnel plate that I made and it fit perfectly. Then I pulled the chassis harness out and got it all zip tied up and put away until I'm ready for some more wiring now that I have most of it roughed in.
Instagram- camaroaj
The Following 6 Users Say Thank You to CamaroAJ For This Useful Post:
camcojb (02-15-2021), Che70velle (02-15-2021), fleetus macmullitz (05-30-2021), Goosesdad (02-17-2021), Spiffav8 (02-15-2021), waynieZ (02-18-2021)
  #475
Old 05-27-2021, 11:50 PM
CamaroAJ's Avatar
Long overdue post. Sorry to neglect the updates, but I promise I've been busy on the car. I'll start with the "list". I was feeling overwhelmed by the amount of stuff I have to do still and made a list of things just off the top of my head that needed to be done so I can focus on a task, well try to anyways until I get to a point I need parts or I'm bored with it for the time being.
Next lets tackle the little tasks I've been working on. Anvil stepped up to help me with my project so I was able to mount my mirrors finally. So big thank you to them for sure. I had to do a little sanding to get the trim rings to fit like they should since these are older mirrors before the rings were even a though. After that they were bonded in as well as the base plate using 3M panel bond.
I also started on the frame work for the package tray waterfall since I have no back seats and the fuel tanks are now in that position. This will get more work later as I have to deiced on what size speaker to use and then incorporate a sub box into it.
I did decide to mount my hood release handle when I could get to it pretty easy since I'll have a cage that would block it if I put it in the kick panel.
The accessory drive, the horns, the underhood fuse block, the brake booster vacuum line have all been mounted, and the extension of the center console has been started.
One of my smaller projects has been working on bucks for the tail lamp molds as I plan on making them out of carbon fiber. I don't spend much time on them, just every so often mess with them for a few minuets.
I also started mounting the supercharger cooler, oil cooler, and power steering cooler. I was really happy with their location, but I might end up moving the power steering cooler. As I had some scrap carbon fiber pieces laying around I used them as part of the cooler mounting brackets.
The engine made its way to the machine shop so I had access to the engine bay again. I decided to move my ECM into the car because of a couple other changes I have planned. That gave me room to cut the hole for the grommet I'm using for the pass through. And before you ask, I don't remember what car I pulled it out of. There is no part number on it and it just says Delphi on it. It was one of the many chassis harnesses I replaced at the dealer throughout the years. I also mounted the positive battery cable bulkhead while I was there and did some weld clean up.
I don't like the idea of all the water getting into my engine bay when I wash the car or it rains, so I did some arts and crafts and made a fiberglass rain tray thats removable with a few nuts on the 5th gen hood vent.
Instagram- camaroaj
The Following 5 Users Say Thank You to CamaroAJ For This Useful Post:
572Camaro (05-28-2021), camcojb (05-28-2021), dhutton (05-28-2021), fleetus macmullitz (05-30-2021), zz430droptop67rs (05-28-2021)
  #476
Old 05-28-2021, 03:01 AM
Wow, nice work!!!!!
CamaroAJ (05-28-2021)
  #477
Old 05-28-2021, 10:18 AM
ScotI ScotI is offline
Nice update.
I've often wondered about the volume of water & its impact under-hood for all the cars w/the current trend/style of hood vents. Seems it would make keeping a clean engine bay almost impossible.
Old 05-29-2021, 11:57 PM
CamaroAJ's Avatar
Thanks guys!
Time for part 2.
Some small stuff I forgot in the last post. The drip rail delete I've started to fully weld. The "body guy" that helped me years ago was wrong on how they should be done so I'm fixing that before it becomes a problem down the road. I metal worked the tubs and got them ready for epoxy and I welded in the edge of the trunk drop to match the wider quarter panel like the other side.
A semi big project I wanted to do was a hood rib delete because of the 5th gen Camaro hood vent. Doing so also required the front valance also be deleted. I needed to do this in stages so that the hood maintained it shape. I supported with clear plexi under the cut out places and laid fresh carbon in a wet layup like you would do with fiberglass and then put a overlapping piece top and bottom to add strength to the joint.
Getting that done I was able to bond the hood vents in. On the side vents after bonding them in I modified the back part so they sat smooth with the hood with some minor fiberglass work. That pretty much wraps up my hood, so it it now ready for body work and paint when I get to that point.
The front lower spoiler is a work in progress. I dabble here and there with it when I'm doing other carbon fiber work. I needed it to be about 3/4" taller, so with pretty much everything else I have from Anvil, I cut it up.
I have been wanting to have a brake cooler duct and another duct to run to the rear for the trans and diff. coolers. My original plan was a set of C7 quarter ducts, but I wasn't able to get the lines right without reall changing the Camaro body lines and I really didn't want to do that. So plan B was to modify the NACA duct in the door/quarter to do both. The wheel well side will duct around and into the brakes kinda like a C6 Corvette did, just with better ducting. The top of the duct will go over the wheel well and through the trunk drop to the diff. cooler on the passenger side. I still need to build the driver side, but it will cooler the trans cooler.
[/url]
Something that has bothered me since the day I welded then in was the finger pockets for the door handles. I made the pockets in a flat piece and then welded in a flat section into a door that is curved. Because there is some support structor in the door no matter what I did I was never able to correct the metal and get the shape it needed to be. So I cut them out and made new panels with the english wheel to add the needed curve.
That brings up to todays update. After a few different designs for the finger pocket for the door handles I just wasn't happy with the shapes. So instead of wasting even more time on them I decided to go with C6 door handles. I made pockets for them to go in the door and then welded them in before metal working them out. Ignore the door edge, it will get finished up when the quarters get welded back on and I can adjust the gaps.
Instagram- camaroaj
The Following 7 Users Say Thank You to CamaroAJ For This Useful Post:
Beechy (05-30-2021), dhutton (05-30-2021), EVIL SS (06-01-2021), fleetus macmullitz (05-30-2021), jarhead (05-30-2021), redfire69 (06-03-2021), zz430droptop67rs (05-30-2021)
  #479
Old 06-20-2021, 10:30 PM
CamaroAJ's Avatar
Ok lets get up to speed on the last few weeks. I finished up the driver side brake and trans cooler duct.
The engine came back from the machine shop and I'm ready to assemble it once I get a few more bolts and bearings ordered. I still don't know what cam I want to go with either. I started working on the supercharger cover by grinding down the Corvette letters and back filing them with panel bond. On the center console I stared to fiberglass the gap until I ran out of glass. The cover and console are coming along nicely tho.
Most importantly I finally got some epoxy shot on the inner structure and have started the final fitment and welding of the quarters. It took a lot longer then I figured it would to get everything fit and mostly welded up. I still have more welding to do across the top and back before I can grind the welds and start the hammer and dolly process. Big step forward to having a whole car again tho.
Instagram- camaroaj
camcojb (06-20-2021), Che70velle (06-21-2021), dhutton (06-21-2021), EVIL SS (06-23-2021), Roscoe03 (06-21-2021)
  #480
Old 06-21-2021, 09:04 PM
Che70velle's Avatar
Good to see updates here. Keep at it man. Love following this build.
Thanks Dad!!
The Following User Says Thank You to Che70velle For This Useful Post:
CamaroAJ (06-21-2021)
