Old 07-17-2021, 09:20 PM
Ketzer's Avatar
Ketzer Ketzer is offline
I believe there is an air-dry version of Cerakote. Might be more durable than paint.
Jeff-
The Following User Says Thank You to Ketzer For This Useful Post:
jarhead (07-11-2022)
Old 07-18-2021, 05:54 AM
I appreciate it, Jeff. I'll look into it.
Does anyone know what GM coated these with originally? I didn't think it was paint.
Old 07-18-2021, 07:57 AM
Powder coat? Of you think that might be too thick ?
Old 07-18-2021, 09:03 AM
Yes, that is my concern with powder coating. The seals for the windows lock into this divider/frame. I'd be concerned with affecting the seal's fitment. It very well could be misplaced concern though. I'm certainly open to the idea if others have powder coated this frame and not had any issues.
Thank you.
Old 07-18-2021, 09:21 AM
Ketzer's Avatar
The thickness is why I suggested Cerakote, a lot thinner coating but supposed to be at least as durable as powder coating.
I mentioned the air dry version because I wasn't sure if Trey planned to pull them completely apart. Cerakote is normally done with a similar process to PC, strip parts, spray on and bake at 350-375...but they also have a formula for more delicate parts (plastics, polymers, etc.) that doesn't have to be baked.
Jeff-
Old 07-18-2021, 02:06 PM
I'll be pulling the entire vent window out of the door. My biggest unknown is how to make sure the metal that's attached to the vent window itself gets whatever coating I put on the frame, too. I have no idea if you can remove that metal from the glass or how to put it back if you can. I'm inclined to simply leave it on and tape off the glass. I really need to find a good C10 forum I think.
I appreciate the mention of air dry cerakote. I've found a thread on a gun forum talking about different coatings that are durable and air dry. Gives me options to investigate.
Old 07-24-2021, 08:20 AM
As I said above, I found a firearm thread that talked about different coatings. Came across DuraCoat which is available in an aerosol can. https://www.duracoatfirearmfinishes.com/ I think I'm going to order some swatches to see which I like. This may be the easiest route for me to get a good coating on the window frame.
The air dry Cerakote is definitely a good choice. I might actually be the best choice. I don't have the spray gun for it though. I'm going to investigate some of the cheaper options for guns and see if I can make my little pancake compressor work without going too expensive on the components. If I was going to be coating a lot, I would invest the expense of a spray gun, etc. I'm just trying to do these little items for now though.
