Old 07-19-2021, 11:16 AM
Kmelander Kmelander is offline
Originally Posted by ScotI View Post
What is your plan for updating the front suspension geometry to match the rear half refinements?
I really like your approach for this build. Very relatable using/tweaking what you have vs. the expensive (& usually faster) route of purchasing new/aftermarket suspension bits.
I'm replacing the front suspension with CPP tubular control arms, Viking coil over shocks and a CPP C5 wheel kit. The wheel kit includes the steering knuckle, ball joints, unitized hub, GM type twin piston calipers plus rotors. I believe the steering knuckle has a raised upper ball joint for improved geometry. The spindle height is listed as stock I believe. The control arms, shocks and springs have arrived. I'm waiting for the wheel kit and I still need to order the front anti-sway bar, steering box and linkage.
Old 08-01-2021, 05:22 PM
The race shop finished up my engine last week so I took a ride up on Friday to see a couple of pulls.
https://youtu.be/X3A7kLBLRVU
The Following User Says Thank You to Kmelander For This Useful Post:
Roscoe03 (08-02-2021)
  #93
Old 08-12-2021, 07:44 AM
update - Both quarters are fully welded and prepped with and 1 skim coat of Duraglas filler. I'll put another coat of the duraglas on each side then finalize the inside seams. For those, I'm planning on brush coating with EW rust encapsulator paint then applying seam sealer.
Roscoe03 (08-12-2021)
  #94
Old 08-12-2021, 02:11 PM
egoman's Avatar
egoman egoman is offline
Kudos on the bodywork. I am dreading the stuff I have to do and its nothing compared to your stuff.
The "Biggest" thing in motocross!
My build thread, Transcona, The dirty old Cougar!
https://lateral-g.net/forums/showthread.php?t=58877
The Following User Says Thank You to egoman For This Useful Post:
Kmelander (08-15-2021)
  #95
Old 08-12-2021, 03:55 PM
ScotI ScotI is offline
What did the details/specs end up being for the motor?
Old 08-15-2021, 07:06 AM
  • 4.030" bore, 4" stroke, Forged crank (eagle I think), Forged H-beam rods, ARP-2000 rod bolts, ARP main studs, I believe zero decked.
  • -12cc inverted dome pistons, 10.5:1 static CR
  • TFS GenX 220 cathedral Heads with Ti retainers (assembled), 65cc, 2.055" intake vlv., 1.57" ex. vlv.
  • Holley UltraXP 750 Carb
  • Comp Ultra Gold Rockers
  • Edelbrock LS1 dual-plane Intake Manifold
  • Cam Motion 231/237 duration @ .050'', 116.5 LSA, 113 ICL (116.5+3.5) , .621''/.612'' lift with 1.7 rockers
  • Hamburger 1" carb spacer
  • MSD LS Ignition
About $12.3k on the dyno.
Old 09-01-2021, 02:12 PM
Finished up a little more body work around the trunk area. Patched up the gutter channels and welded up the tail light panel body seams plus a coat of filler over the welds.
The Following 2 Users Say Thank You to Kmelander For This Useful Post:
Roscoe03 (09-02-2021), syborg tt (09-12-2021)
  #98
Old 10-12-2021, 10:13 AM
Bit more progress to report. I've got the dash repaired and back in the car, which was a good bit of work. I gave the dash and firewall the same treatment as my inner quarters. Also finalized the cage. Added a few more bars and gussets. I'm working on the transmission cut-out now.
Old 01-12-2022, 08:02 AM
short update - Still working on the old girl. Lots of prep, making and spray-work.
Roscoe03 (01-16-2022)
  #100
Old 01-12-2022, 09:43 AM
Progress is nice. Thanks for sharing the updates.
Kmelander (01-12-2022)
