Old 11-05-2021, 09:53 AM
samckitt's Avatar
samckitt samckitt is offline
What is the issue with plumbing if you use an LS style throttle body? Is there interference with using the LS TB or is there vacuum lines going to the Caddy TB? I would think it would be easier to change plumbing vs the electronics, but without seeing it I'm probably wrong.
Scot
86 Monte SS
LS2/T56 Magnum
Old 11-05-2021, 03:44 PM
ataves1's Avatar
ataves1 ataves1 is offline
The Cadillac TB fits in the dog house (kind of what it looks like) at the rear of the supercharger. You're not wrong, I am hoping to find an LS TB that can fit in there. It would make controlling this thing considerably easier and cheaper. It wouldn't be too difficult to move it up stream a bit but I'm looking for an OEM look fit up. The big issue with the Cadillac TB is that I can't confirm throttle position sensors have the same curves or that the motors respond the same to signals as an LS one. Systems from Haltech or FuelTech can handle this no problem but they are big bucks.
