Old 01-12-2022, 05:18 PM
syborg tt's Avatar
Originally Posted by Panteracer View Post
All the wiring on my new Gt-1 car has plastic
dip over all the final connections to keep things together and my guess
prevent corrosion. Never have seen that before. Every bolt is very hard
to break loose on this car... very impressed whoever put it together.
Like dirt bikes race cars have bolts falling off them all the time
Love the way you keep your wiring all run cleanly
Bob
Thank you Bob and now you need to show the pictures of the wiring connection on your GT-1 car.
Nice work, Marty! This is going to be really clean under the hood.
Thank You Trey
Originally Posted by Gmachine1911 View Post
Looks really good, Marty, you’re attention to detail is amazing! I was admiring what I suspect to be your transmission cooler lines running along the top of the subframe…I’ve gotta decide what type (hardline or flexible) and where to run the lines for my Nova project and was wondering if you used PTFE lines or something else?
Thank you Shane and to answer your question I used the Holley PFT Line for the trans coolant lines. I talked to the guys at Holley and they said no problem and I could use this line. Man I hope he was correct. On a side note I will be connecting to the Hard Line that Kenny made.
marty-mj
Last edited by syborg tt; 01-13-2022 at 05:14 PM. Reason: Added Hard Line Note (( 01-13-22 )
Old 01-12-2022, 06:05 PM
syborg tt's Avatar
Default Yep, I am still playing with the Trans Coolant Lines ( 10-24-22 )
I found these clamps on Amazon and they do a great job securing the lines.
Checking for clearance under the upper control arm and there is plenty.
Yep, I cut the wrong length of the heat sleeve when I made my last cut so now I have to order more.
So, I jumped over to the battery wires as I needed to do something a little different and then I called it a night.
marty-mj
fleetus macmullitz (01-12-2022)
  #1713
Old 01-12-2022, 06:15 PM
syborg tt's Avatar
Default Holley Cylinder Head Ground ( 10-30-21 )
Cylinder Head grounds are complete ( 10-30-21 )
JIC anyone wants to know this is the size of the bolt that is on the back of head.
marty-mj
camcojb (01-12-2022)
  #1714
Old 01-12-2022, 07:03 PM
sru1436 sru1436 is offline
Looking good, can you send me link to those clamps you found on Amazon?
Old 01-12-2022, 07:52 PM
Probably like these. But when they claim they fit #8 AN, they mean hardline not braided lines. In other words, the #8 clamps are for a hose or line that's 1/2" o.d. Order accordingly.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
  #1716
Old 01-13-2022, 10:43 AM
syborg tt's Avatar
Hi Jody,
These are the one's I ordered for my -6 Hose
https://www.amazon.com/6AN-Hose-Sepa..._rp_111_i&th=1
marty-mj
Old 01-13-2022, 11:16 AM
Hi Jody,
My point was that they give o.d. hose/line measurements for their sizes. So a #8an is for a hose or line that's 1/2" o.d. Perfect for #8 hardline but too small for a #8 braided line. As long as you know the o.d of the hose you're using and order according to that instead of just the AN size you're good to go. Quality was good for the price.
At least the ones I ordered were sized that way. If you're using ptfe braided lines the o.d. will be much smaller so maybe their sizing works. I was trying them on a couple of standard rubber lined braided lines.
syborg tt (01-13-2022)
  #1718
Old 01-14-2022, 07:39 AM
Thank you.
Old 01-14-2022, 07:34 PM
F'in mine's Avatar
All of the wiring has been heat wrapped going to the starter.
You've set the wiring standard pretty high for the rest of us with your meticulous detail to wiring. I too went overboard with shielding wires and fluid lines around the headers and areas that give off heat, on my starter to battery cable and alternator cable I added the spark plug protector boots for an extra added measure of protection, inverted them to take out the ring.
Name:  ICT engine plate brackets.jpg
On another note just wondering what single fan you're using? Is it for less fan/rad depth, less air intake tube interference?
Keep up the great work!
1969 Camaro SSRS
Simon
The Following User Says Thank You to F'in mine For This Useful Post:
syborg tt (01-14-2022)
  #1720
Old 01-15-2022, 04:25 PM
syborg tt's Avatar
Default Intake Manifold Fittings ( 10-30-21 )
Planning ahead before I run over to Ace Hardware for some fittings as the one's that are supplied are useless.
So the Earl fitting that I happened to have looked like it was going to work. However, It did not as it hit the valley cover.
So I found my Mike Norris Catch can and I used these fitting to start mocking up the fittings I needed.
After a quick trip to Ace I think I have the fittings I need.
Only at Ace can you find a 1/8" Hose Barb (trust me I looked everyone else)
First Mock Up
marty-mj
camcojb (01-15-2022)
