Old 01-16-2022, 08:45 PM
SuperBuickGuy SuperBuickGuy is offline
it was a shuffle day, so it ended with wiring on the Corvette... however, well... some old friends got moved
as with all great things... I had to 'just' change a fuel filter... what an ordeal, seems the last owner didn't bother putting one seal in place - which made the fuel filter pointless.... grand
so plan b was employed
moved to get this back in the shop - it'll have its own thread, but it's Buinicorn - 6.0 LS powered Buick wagon
I can't believe how rough this car is.... ugh
installed in its new home
the day finished with me getting this reinstalled
The Following User Says Thank You to SuperBuickGuy For This Useful Post:
Roscoe03 (01-22-2022)
  #42
Old 01-17-2022, 09:51 PM
how to haul 12' material....
and ouch, prices
and the interior comes further apart
to be installed
on the lock lever
​​​​​​​tomorrow.
  #43
Old 01-18-2022, 09:45 PM
window alignment and locks.... but tonight... all alignment so you get a couple pictures
it took a lot of fitting and elonging holes to get everything to line up
not joking, this is where I started, was worried at Optima they'd call me on this... thank god the FiTech computer scrambled... sheesh
of course, what would a night in the shop be without needing parts - the regulator on the driver's side is new, the passenger side is not and it needs replaced.... ah well, I have plenty to do in the mean time.
Old 01-19-2022, 10:01 PM
Door locks. I've actually come out to people sitting in my car. They still live, but let's slow the idiots down
weld a tab to the lock bar
all fits under the panel
of course this door can't go together because I'm waiting on a regulator.
Old 01-20-2022, 09:45 PM
driver's side done more detail
pull wires
actuator install
it was simply easier to weld a tab to the rod to connect it all up
and just like that, connected
and reassembly of the dash
once the right side regulator gets here, I'll assemble the right side.... between now and then, I have plenty to do... some of the aero should be here tomorrow....
Old 01-24-2022, 09:33 PM
I have little confidence that this will survive in any recognizable form but I want the inlets and most of the shape - but it's too narrow for my plans so fiberglass fab is coming soon
first part of my wing arrived
and the regulator
Old 01-26-2022, 10:43 PM
In other news, Fedup strikes again.... the brackets were supposed to come with the wing - and they're not delivering the wing.... my guess is they destroyed it....
No, you do not have to remove the glass or the outside weather strip....
the parts
getting close the bloodletting being done - but notice that the bottom hole isn't aligned - Chinesium strikes again. Nice touch that all the bolts are 10mm socket head
Old 01-27-2022, 11:16 PM
door assembly
of course, had to modify... smh
back together... woohoo
Old 01-28-2022, 05:30 PM
and the driver's side window doesn't go up... oh good grief
in other news
dies arrived
Old 01-29-2022, 03:32 PM
and part 2....... still one more part
