Old 01-21-2022, 08:46 PM
SSLance's Avatar
SSLance SSLance is offline
The nuts we tried to weld to the stud were so small they melted down before the weld would burn into the stud
Turns out, several drill bits and an easy out with assist from blue wrench was the answer.
New bolt procured and ready to put all back together now.
Lance
The Following 4 Users Say Thank You to SSLance For This Useful Post:
camcojb (01-21-2022), jarhead (01-25-2022), mfain (01-22-2022), syborg tt (01-22-2022)
Old 01-22-2022, 12:02 AM
SuperB70's Avatar
SuperB70 SuperB70 is offline
I've noticed that those easy out taps are bad in same cases. They split and widen the bolt so its even more thighten.
Every place I can, now days I use tig to get those out. Little by little grow new crown to it, when its high enough weld a nut on and then comes the most important: then let it cool all the way. Dont try to turn even a little bit before. Will just broke the nut off.
Not so long ago, got a broken stud out off 6.0PSD head. Friend snapped one off when changing injector. You cant drill, you would have to remove the head. This way it was easy..
, Juhani
The Following User Says Thank You to SuperB70 For This Useful Post:
Old 01-22-2022, 01:44 PM
ScotI ScotI is offline
Was that a GRADE-8 bolt that broke?
Old 01-22-2022, 04:38 PM
SSLance's Avatar
No, 8.8 grade 8mm OEM bolt.
Lance
Old 01-23-2022, 10:24 AM
syborg tt's Avatar
Have you ever tried the left hand drill bits as I have had great luck with them.
marty-mj
Old 01-23-2022, 07:18 PM
Hawks third gen or Hawks performance, whatever he goes by now, has both the t bolt and fork now. I put new ones on my TA. Parts looked good when they arrived.
Old 02-26-2022, 07:10 AM
SSLance's Avatar
Got some work done on the car this week with positive results all around. The LCA axle mounts have been lowered 1.5" and a brace was added between the UCA frame mount and the pass side spring tower. Here is how the geometry ended up.
I can now dump the clutch and send the car into a drift with virtually zero wheelhop, huge difference than before. The forward bite\grip seems to be much improved as well, but won't really be able to test that until I launch it at the start on hot tires at next event.
I also had Dr EFI go back through my Holley tune and clean up a couple of things and OMG is it better now!! Andrew is getting really good at this and with his touches in a few places and the restrictive tailpipe delete, this thing really came to life. Can't wait to show the LS powered, big tire guys how well it works March 13!!
Lance
camcojb (02-26-2022), Che70velle (02-26-2022), mfain (02-26-2022), syborg tt (02-28-2022)
Old 02-26-2022, 04:42 PM
Glad to read you're netting POS results from the efforts. Looking forward to track-day updates!
