Old 01-30-2022, 05:59 PM
Mad_Monte_Carlo's Avatar
Mad_Monte_Carlo Mad_Monte_Carlo is offline
Originally Posted by SuperBuickGuy View Post
and part 2....... still one more part
Where about in Washington you from?
Old 02-03-2022, 09:13 PM
SuperBuickGuy SuperBuickGuy is offline
Woodinville for now, hopefully Spokane soon
2 hours of set up later
Add some shims to the front, top
-2.25 degrees camber is too much
-1.65 is a good 'next' point. with a cross camber of less then -0.01
My first alignment was 1.0 and it understeered
I also set the toe to 1* front 2* rear and the rear camber is the -0.9
caster is whatever I can get - 5 degrees or maybe a touch more
I'll see how that does on Sunday on the season opener autoX
The Following User Says Thank You to SuperBuickGuy For This Useful Post:
Roscoe03 (02-07-2022)
  #53
Old 02-08-2022, 09:15 PM
Time to make the die for the gas tank
center the top punch (aka top die) on the bottom die
weld on both sides
build tank
simple, no?
Roscoe03 (02-10-2022)
  #54
Old 02-10-2022, 09:33 PM
you know the day is going to go bell up when you're using a razor blade to clean PVC off stainless. Basically it adds hours of refinishing because no matter how good you are, you'll scratch it..... and before someone pipes up 'ceramic - that scratches it too.... just doesn't last as long
time to assemble the internal stuff - Hydramat
I'm using a lot of parts I've had around... like the hydramat from the first fuel system
time to decide whether to lap or butt weld it...
tune in Sunday for the exciting answer
Old 02-13-2022, 08:54 PM
Tanks for the memories?
with my gear, precision rolls are not a likely result...
what stopped me tonight is I need more clamps.... seriously
drove it yesterday, this is too restrictive so went back to the old air filter
Old 02-16-2022, 09:28 PM
onward
I think I ended up using every C-clamp I have
I also made an adjustable right angle to hold it square. If you're doing this, don't lure yourself into just welding it then pipe clamping it square.
weld a bit, let cool, dolly, repeat
once the outside is welded, I run a hot bead down the inside with an aluminum bar against the outside - it sucks the weld 'flat' with the top... less grinding to make pretty
woohoo, I made a tube
crack check, then baffles, sump, fill neck and finally end caps
Old 02-17-2022, 10:07 PM
somewhere in my workings, pedals will happen
might as well use my aeromotive pump
Old 02-18-2022, 12:50 AM
Nice work!!
Old 02-18-2022, 03:58 AM
Beechy's Avatar
Beechy Beechy is offline
Are you tig welding using stainless filler rod on the tank?
Jim Grant
Melbourne, Australia
(Dual citizen)
Old 02-18-2022, 06:59 AM
I am all of it is 304 stainless (tank and rod)
Beechy (02-21-2022)
