Old 03-08-2022, 09:16 PM
SuperBuickGuy SuperBuickGuy is offline
time to cap
key here is to not go fast
and be clean
hopefully crack checking tomorrow night
Old 03-09-2022, 08:43 PM
onward
welded 1/2 last night, other half tonight - and did it over a couple hours so I didn't get warping
pretty welds leak. My goal here was full penetration - thus the weld has some grey in it - key here is the HAZ is even (heat affected zone)
and all those black marks are holes - to check for leaks - I look for holes or HAZ changes
for whatever reason, this side didn't have any
then I put 7 or 8 psi in the tank, spray soapy water on the seams and blow bubbles
hmmm more bubbles
leaks fixed, clean up the tank.... next up, removal of the old tank eventually this will have tabs on the bottom so I can attach a defuser and also attach the rear panel to it
The Following User Says Thank You to SuperBuickGuy For This Useful Post:
camcojb (03-09-2022)
  #73
Old 03-10-2022, 09:51 PM
time to test fit
old tank
and out
get the fuel out... was joking with my dad that between the fuel in the tank and the nickel in the tank I should be concerned they'll both disappear
now you can see what the plan was
even got pretty close lining up the fill spout - the plan all along was an offset then straight into a coupling and the filler
Old 03-12-2022, 09:22 PM
tonight started mapping how I'm going to accomplish the tasks
was kind of hoping there would be some 'dos' and 'dont's' from the seller... guess not - this needs to attach to the deck and be supported underneath to the frame
here
the optima battery is 1" wider... so new battery box coming
part of tonight was a failed attempt to figure out whether the wire with a knot or the brown wire were the reverse light wires... I have a schematic - but who knows where
tomorrow I will spend some time on this but most of the day will be spent looking for used parts that I don't need....
camcojb (03-13-2022)
  #75
Old 03-13-2022, 09:17 PM
Battery, cont.
it's like 1" wider... so a new tray is in order
and off
new tray
and installed and painted
at the swap meet today, I took a chance on several of these...
makes getting the burn off a lot easier
and reverse light....
Old 03-14-2022, 09:28 PM
time to give it wings.. or a wing
aluminum angle
some solid eyeball calibrating followed by serious staring
wing held on by hopes and prayers with an assist by gravity
it's about here I'm considering whether or not I like the stands.... they need to parallel something, e.g. the rear valence and let me be SUPER clear, I approved the design. CIRO did what I asked them to do...
my brave act of the night
now in place
thankfully, I have a plasma table... basically the wing will end above the end of the deck - so it will move horizontally.... no big deal
love it
a good view - the stands will mirror the rear angle - also, I have to build an 8" version for Optima.
paint is dry so I can finish this as well
Old 03-15-2022, 12:00 PM
I rarely ask opinions - mostly because they're someone else's preference (which is fine, and I have my own).
But here, I'm kind of stumped.
the angle
do I match the B pillar window frame or the tail light panel with the struts?
Old 03-15-2022, 09:48 PM
onward with fastening
Luigi is checking out the progress too
notice the tail blur? he is one active dog (love it)
bolted down
with pads to pretend we're saving the paint
and tied to the frame
tomorrow weld
Old 03-16-2022, 09:03 AM
Panteracer's Avatar
Default Plastic 76 Corvette
I like the struts layed back a little so matching the
back of the car. I have changed the ends on mine
multiple times... Starting to rework the ones on my
Gt-1 race car plus raising the wing some
Bob
The Following User Says Thank You to Panteracer For This Useful Post:
SuperBuickGuy (03-16-2022)
  #80
Old 03-16-2022, 10:05 PM
choices.
The A1000 pump is good for 1200 hp and has -12 lines in and out. The Holley system right now has - 6 lines and makes 500 wheel hp
I've been going back and forth about upgrading lines. I have most of what I need to upgrade to -10 supply and -8 return.
But
at this point I'm already pushing noise limits and 700 hp is at 7000 rpm. As it is now, it's got a physical cap on noise - set the rev limiter to 5500 and life is fine.
But yeah.
my only real concern if I leave it all -6 is it puts a lot of stress on the pump but with that said, I can turn the pressure up to 75 psi if I really want more power... after all volume is a function of pressure
got more done tonight, though.... think I'll stay with -6 for now.... but when I build more power, I'll update. At this moment, the car is fast enough for my skills.
line test
starting to lay out how the tank will be mounted
I also need to put an offset in the fill tube to line up with the gas cap (3 7/8 offset)
I also welded in the braces - brackets got a coat of paint so drying... bolts get here Friday
