Old 03-16-2022, 10:32 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Default USB ports
Guys, can anyone recommend a good USB port to install in my Camaro. I've seen a variety of choices on Amazon...some with good reviews and some not so good. I know at one point Ironworks was selling them, but don't see them on their website anymore. Does anyone have any recommendations or any real world experience with some?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-16-2022, 10:42 AM
68454RS's Avatar
68454RS 68454RS is offline
not sure i'm answering what you're asking but I purchased a cheap 2 port from Amazon and mounted it in my shifter plate
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Old 03-16-2022, 12:15 PM
sleepertime's Avatar
sleepertime sleepertime is offline
Post
One thing to think about is the USB 3.0 which most items these days require the higher output for fast charging. Here is an example of one with USB 3.0 that has a built in power switch. This model if wired thru a switched 12 volt source would need to be turned back on after every power cycle. There are other models that do not have the switch.
https://www.amazon.com/dp/B08LKRDG2T...mcd_asin_1_img
My build BRNAGN 1969 camaro SS
Old 03-16-2022, 01:52 PM
samckitt's Avatar
samckitt samckitt is offline
I have thought about doing this as well and thought about going to the local Pick-n-pull to find something GM & cut enough length of harness from it to splice in where I need it.
Edit. I have also purchased this from amazon for our boat. The radio is a pain to get to, so I mounted this where it has easy access so I can play/charge my phone through it.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-16-2022, 06:24 PM
214Chevy's Avatar
Yes, you answered correctly. I want to mount mine in the console as well. Thanks!
Thanks for all of your input guys. Yeah, there are lots to choose from on Amazon. Thanks for your input.
'68 C10 swb
'72 Chevelle
Old 03-16-2022, 08:30 PM
WILWAXU WILWAXU is offline
I used this one on a mustang project. I mounted it in the cigarette lighter hole.
https://www.amazon.com/BATIGE-Waterp.../dp/B01NCA9XEI
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 03-17-2022, 11:19 AM
214Chevy's Avatar
Thanks John...I see the general consensus is guys are buying from Amazon. So I just need to choose one.
'68 C10 swb
'72 Chevelle
Old 03-18-2022, 01:32 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
i just got one off Waytek. I installed it in the console box of my 77 Z28
Scott from NJ
Old 03-19-2022, 08:24 AM
214Chevy's Avatar
Thanks Scott...
'68 C10 swb
'72 Chevelle
Old 03-25-2022, 07:50 AM
TechNova TechNova is offline
That thing is huge judging by the finger!
