Old 05-18-2022, 03:18 PM
68454RS's Avatar
68454RS 68454RS is offline
Default Hyd clutch questions
Kind of broad ranging question, doing the T56 swap and Hyd clutch on my BB 68. I've seen some posts on here and other forums that talk about when the clutch release/engages, pedal travel and over travel and the need for a travel stop on the clutch pedal. What's the truth and solutions? Is a pedal stop needed? is the release/engage point an issue? what don't I know that I should? Am I overthinking this?
Old 05-18-2022, 08:53 PM
camcojb camcojb is online now
You do need to limit the travel as the clutch master has a specified range of motion. Exceed that and you can/will damage it, possibly the clutch or the release bearing. In some cases the floor acts as the stop, just make sure to measure the stroke and make sure it's in spec with what the clutch master manufacturer wants. Otherwise you need to fab up a mechanical stop.
Here's some universal ones.
https://www.google.com/search?q=univ...client=gws-wiz
Old 05-19-2022, 07:03 AM
68454RS's Avatar
Thanks, Looks like something as simple as a rivnut in the firewall and a carriage bolt with jam nut.
The Following User Says Thank You to 68454RS For This Useful Post:
camcojb (05-19-2022)
Old 05-19-2022, 07:50 AM
68454RS's Avatar
How do I know what my stroke is?
Old 05-19-2022, 11:22 AM
Mark your clutch rod where it goes through the firewall with the pedal up in it's resting place. Then make a mark at the max distance listed with your clutch master, say 1.2" for example. Slowly push the clutch pedal down and see if the pedal will go past the second mark before bottoming out. If it does you need a pedal stop to limit that distance to the clutch master specs.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
ADY (05-19-2022), RdHuggr68 (05-21-2022)
Old 05-20-2022, 09:50 AM
68454RS's Avatar
Thanks Jody
camcojb (05-20-2022)
Old 05-20-2022, 12:06 PM
68454RS's Avatar
I ordered one of these
https://www.ebay.com/itm/184910942178
Old 05-20-2022, 04:49 PM
srode1 srode1 is offline
Ask the seller to send you the long version. He has both but only one listed. If too long you can cut it shorter
Old 05-21-2022, 08:00 AM
68454RS's Avatar
Dang it, YOU told me that elsewhere and Unfortunately, I failed to ask and it's already shipped. I'll have to make do with what I get.
Old 05-21-2022, 01:41 PM
you may be fine, and if not you can just get a longer bolt to use, shouldn't be a big deal. I needed the longer one for mine, but I had measured before I ordered it.
The Following User Says Thank You to srode1 For This Useful Post:
68454RS (05-22-2022)
