Old 05-30-2022, 02:15 PM
Stielow's Avatar
Stielow Stielow is offline
Love how you integrate the later model factory pieces. Is it okay to add this one to your website?
Sure what every you think.
Stielow Engineering
Old 06-01-2022, 02:48 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
I love how your "custom" builds integrate a lot of stock GM parts. Are the radiator top mounts a stock GM part also or something you had built?
Jose
Old 06-03-2022, 04:50 AM
Stielow's Avatar
Sled Alley built those but the rubber isolators are 2022 Caddy CT5. The lower isolators are 2022 full size truck. I’m sick and tired of failing radiators. Use the GM stuff and it should last 100k miles easy.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (07-28-2022), syborg tt (07-31-2022)
  #34
Old 06-03-2022, 06:55 AM
ScotI ScotI is offline
Your statement has me wondering..... "Failing" as in aftermarket vs. OE or just in general?
Old 06-03-2022, 09:17 AM
thedugan's Avatar
thedugan thedugan is offline
I thought the issues he had in the past (Red Devil or LT5) was not enough movement of the Radiator and Fans assembly even having it rubber mounted to the core. So he wanted to go with a frame mounted unit like GM uses in all cars to allow it to move around a bit and not break anything. At least that was the story on the Camaro's.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
The Following User Says Thank You to thedugan For This Useful Post:
  #36
Old 06-03-2022, 09:45 AM
Yes, I was aware of that. I wasn't sure when he began the 'floating' mount locating vs the old school bracketry. My question was more toward is there still issues w/aftermarket radiators failing w/the updated mounting method?
  #37
Old 06-03-2022, 09:56 AM
thedugan's Avatar
Ah got ya. Hope not have big money in my Autorad setup..
Doug L.
  #38
Old 06-05-2022, 06:04 PM
Stielow's Avatar
Yes, Failing aftermarket radiators. They have gotten better.
Stielow Engineering
ScotI (06-06-2022), syborg tt (07-31-2022)
  #39
Old 06-10-2022, 01:20 AM
Stielow's Avatar
Starting on the exhaust
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (07-28-2022), Roscoe03 (06-10-2022), syborg tt (07-31-2022)
  #40
Old 06-10-2022, 01:22 AM
Stielow's Avatar
Engine bay is clean now it is time to start putting it back together.
Stielow Engineering
The Following 6 Users Say Thank You to Stielow For This Useful Post:
214Chevy (06-11-2022), dhutton (06-10-2022), fleetus macmullitz (07-28-2022), Mikael A (06-12-2022), Roscoe03 (06-10-2022), syborg tt (07-31-2022)
