Old 07-20-2022, 07:29 PM
Hydratech®'s Avatar
Supporting Manufacturer
HydratechBraking.com
Question Advanced rust removal
I have been working with a lot of chemistry lately in removing rust from vintage cast iron cylinder heads, engine blocks, intake manifolds, various parts... Electrolysis has been working astoundingly well, watching the solutions start bubbling and sizzling when power is applied (anode / cathode process using a battery charger). I have been working with super washing soda, white vinegar, and then finding that an electrified mild solution of muriatic acid has been the most effective - amazing actually, bringing 50 year old castings into what looks like a brand new part that just came out of the foundry! Makes Evaporust and other similar rust removers look like child's play.
So here's my problem. I have been experiencing corrosion just about literally after removing the parts from a good long soak in a baking soda solution that is supposed to neutralize the acids. I just can't seem to stop the instant flash rusting. When I say instant, I mean right in front of your face within 30 seconds. Spraying down immediately with WD40 does seem to help, but the castings still darken up, not looking like the brand new casting you see when you first pull the part out of the solutions (which is what I am after).
Has anybody here had experience with this? Can you tell me what I am missing? I know that cast iron castings are porous, and that the acidic solutions are soaking in deep, especially with electrolysis, which is exactly great for removing the 5 decades of corrosion, but I can't quite seem to nail down the "quenching" of the process. I need to nail down how to conclusively stop the reaction of being exposed to air once dried. I have researched this out on the ol' internet trying all kinds of methods. When I do seem to achieve some success, it comes at the cost of producing blackish magnetite across the castings. When you see what looks like a brand spanking new cylinder head come out of the electrolysis process, you are amazed, but then that all goes south just about right before your eyes. I have not yet tried what one ol' timer told me to do, which is to get some blocks of zinc and set up a quenching bath in a separate tub reversing the polarity of the electrolysis so that the zinc blocks become the sacrificial anodes to feed the castings. Again, sounds like it may work, and could even possibly result in yet an even better looking casting pickled in zinc.
Your experiences? Thoughts? Suggestions?
I have got it almost nailed down, but am apparently missing the last step to success. If I can get the castings to air dry and stay looking like the brand new castings they look like when first pulled out of the cleaning solutions, I will be over the moon (and can stop pulling my hair out in frustration).
Let me know please - thank you kindly!
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 07-21-2022, 05:53 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I have zero knowledge about any of this, but reading through your comments you don't say how much humidity is in the area where you're running the experiments? May not even be a humidity problem, could just be the evaporative nature of coming out of the acids into regular air... thanks for sharing though! Interesting stuff!
Jeff-
Old 07-21-2022, 06:00 AM
dhutton dhutton is offline
Flash rust is almost inevitable when you have super clean metal. A light media blasting should clean it up.
Or maybe a quick dip in evaporust.
Old 07-21-2022, 07:00 AM
jarhead's Avatar
jarhead jarhead is offline
Paul,
I have been using electrolysis for 10 years or so, started on old Ford tractors at first. I live in northern Colorado so i don't have to deal with much humidity.
After i pull the part out of the electrolysis tank i power wash it and then spray it with Klean strip concrete and metal prep. I don't know if there is a problem with automotive paint adhering, it works with tractor paint. I wipe it down with lacquer thinner before priming. The paint on my 42 Ford tractor never peeled or lifted. I'll find out on my Torino i guess
You can buy Klean Strip at big box stores, i get it at HomeDepot.
Joe
joe
Semper Fi
My 68 Torino
Old 07-21-2022, 10:43 AM
Products that leave an acid or salt film should not be used with epoxy primers despite any manufacturer claims to the contrary imho.
jarhead (07-22-2022)
Old 07-21-2022, 05:24 PM
TechNova TechNova is offline
WAG here but could you put some type of oil in your tank that would float on the surface? When you remove the part it would be automatically coated to prevent rust.
Old 07-22-2022, 04:17 AM
jarhead's Avatar
Thanks Don,
I've already sprayed some on the bare shell of my Torino, what do i use to clean it now?
sorry for any confusion i caused.
Thanks, Joe
joe
Semper Fi
My 68 Torino
Old 07-22-2022, 04:53 AM
Originally Posted by jarhead View Post
Thanks Don,
Thanks, Joe
Hard to say but I would reapply the product, scrub with a scotch brite pad and rinse it off well with water while still wet.
Old 07-22-2022, 04:46 PM
Hydratech®'s Avatar
Post Electrolysis is cool, but...
Electrolytic rust removal is wild, in that you can watch the rust melt right off, and also see how incredibly clean the coolant passages have become way deep inside of a cylinder head. What I am finding is that I appear to be up against the process in both parts of the actions - the electrical charge aspect and also the acidic actions. I thought I had an intake manifold (cast iron) figured out, by finish soaking it in a baking soda solution, thoroughly drying out in the hot sun (quite hot to the touch after an hour), then media blasting it afterwards to remove the initial flash rusting (that appeared while drying out in the scorching sun). As a test, we also then blasted another cast iron intake that didn't go through the electrolytic cleaning action.
The intake that was only blasted has successfully stayed on the shelf here in the climate controlled shop without any noticeable corrosion forming in 7 days time already - just removed from the blasting cabinet and thoroughly blown clean. The intake that we put through electrolysis, quenching in a baking soda solution for 48 hours, then dried hot to the touch out in the sun, then blasted clean barely made it 24 hours sitting next to the other intake before starting to flash rust again (doh).
So either there is still some acidic activity still deep in the pores of the cast iron (my best guess right now) that doesn't want to neutralize in the baking soda solution (that is supposed to do it), or the electrical charge process is still affecting the casting lighting off flash rusting. Despite the hellacious heat and humidity outside here in TN right now, indoor shop readings are 72 degrees and 40% humidity. Removing the part out of the solution and drying off as quickly as possible with two air hoses wide open on the part indoors does nothing different, versus using a single blow gun outside in the fiery sun. As the part dries, here comes the flash rusting. A quick dip / spray down with Evaporust seems to help, but then becomes blotchy with dark mottled spots of Magnetite forming, with flash rusting still forming in places. I will have to try the Kleen Strip Concrete and Metal prep - might just do the trick, especially if you say you pressure wash the parts first. Do you dry the part before applying?
Since this has been happening, I am going to try some smaller cast iron test parts to see what may happen if I:
1) Oven bake the part to say 250 degrees after removing from the baking soda neutralizing solution. Maybe this will cook the parts into not flash rusting further by outgassing anything still hiding under the surface.
2) Will try the DIY plating angle as a finishing step, as it seems to mirror the electrolytic cleaning steps BUT using a sacrificial anode in a last step in a separate tub. Maybe this will feed the cast iron a barrier that can conclusively seal it. If this works, it may be even cooler still by not only quelling the flash rust, but also lightly plating the casting for a possibly improved appearance. Not sure yet, thinking to try zinc or copper. A greyish colored casting with zinc maybe, and a copperish colored casting with copper? Anything other than flash rust will be a win.
3) Spraying or dipping the casting down in straight antifreeze as soon as it is pulled out of the neutralizing solution. We have all seen cast iron water pumps and thermostat housings that are rusted to all hell on the outside, but immaculate on the inside, running a mix of water (which would induce corrosion) and the antifreeze inhibiting the corrosion. I have been thinking about it but haven't tried it yet. Could it be that simple? Likely no, but worth a shot.
I also understand that many castings are phosphate dipped during initial manufacture to seal any porosity and inhibit corrosion. Just blasting the surface of the casting may be what is not disturbing the overall metallurgy, while the ultra-deep cleaning electro-chemical reactions are going much deeper into the castings. While driving any corrosion out hiding under the surface of a casting seems to be providing a stunningly clean part, watching it change right before your eyes into something less is disheartening. I am determined to find a solution (no pun intended) for the problem. If / when I do, I will let you know. On the flip side, if somebody has anything further to offer that I can try, I am all ears!
Old 07-22-2022, 09:04 PM
bretcopsey bretcopsey is offline
Paul,
Joe
I have had really good results with sheet metal using this product. I have parts that have been treated with this product and left otherwise bare for years barely showing surface rust. I’ve included some before/after pictures, smaller parts were left to soak. For larger pieces I found the key to be agitation with scuff pads or a wire brush while keeping it damp using a spray bottle. The bed of my 51 is still bare years later.
For me, hydrochloric aka muriatic acid was far too aggressive and I had the same flash rust problems you’re describing. I also had concerns after doing research and reading about the potential for cracking due hydrogen embrittlement. I would personally not feel comfortable experimenting with cylinder heads, blocks etc. that I planned to use without getting input from someone that truly understands the metallurgy.
The Following 2 Users Say Thank You to bretcopsey For This Useful Post:
camcojb (07-22-2022), jarhead (07-23-2022)
