Old 08-17-2022, 05:03 PM
SuperBuickGuy SuperBuickGuy is offline
potato camera for the blur again
stock clearance
new wheel clearance
rear stock
rear new
I know this sounds really dumb but I'm going to cut and widen the front fenders to put larger tires on it. The bright side is I know how to do this so it'll only cost me time and materials. right now, it's about 1/2" outside the fender on the stock side and 1" on the new side. With the changes I'm going to make the control arms, I'll have about 1/2 of that solved but I want 315 front tires, not 275. Bright side is I'll 'fix' the paint flaws the painter did when I do this and resolve a couple other paint issues... thankfully it's black and really easy to match
The Following User Says Thank You to SuperBuickGuy For This Useful Post:
camcojb (08-17-2022)
Old 08-29-2022, 09:40 PM
Tires... I can't do it. I keep trying to convince myself to either go square or go with the slicks as a rear tire - all to get a 200tw tire. I'm sorry, but 10% more contact patch should easily equal any 'better' traction I get from the smaller, narrower tire.
... the comparison
the left is what's on the car now
now a 325 v. 345..... while I know what I just said above there is a 200tw tire from continental, problem is the rear is a 345 not 325.
not bad until you realize that where it doesn't really fit would be nearly impossible to make a decent-looking flare
I hate to say it but either I'm going with a right size tire and the wider front (which is where most of the problem lay) in a 340 or so tw.... but now that that's out there - talk me out of it....
in other news, rear, adjustable sway bar from UMI
and new Hotchkis for the front...
and new gears... 3.91s (not 3.73 as previously reported).... I know, I know, I wasn't thrilled with them in the 06 GTO I had, but I think this is different because bigger tire, more hp and lighter car. At this point, 2000 rpm in 5th gear is 85 mph.... and I'm frying the clutch taking off from a standing start.... bonus is big smoke shows.
and adding a cooler to the rear diff
what is wrong with me? (rhetorical, sit down FGZ)... I won't spend the dollars to toss the lunchbox lockers out of my FJ40 but will spend it to upgrade to a geared limited slip in the C3?
camcojb (08-30-2022)
Old 08-30-2022, 09:42 PM
So I'm tired of relying on people to do ring and pinion swaps for me. Now is an optimal time to learn
mark the caps
get caps off
spend rest of night looking for pry bars... moving is SO much fun....
*and in case any of you are silly enough to follow my instructions, this is, if I count all of the ones I've done in my life... is the first. I did try once before but I couldn't get the gears to give a good pattern. Turns out I did it right but the case was junk.... anyway, there's the warning
camcojb (08-31-2022)
Old 09-01-2022, 09:24 PM
it's out
A screwdriver in the hole and a couple hits of the pinion flange with a dead blow and out it came
wow is that a lot of clutch debris.....
The Following 2 Users Say Thank You to SuperBuickGuy For This Useful Post:
camcojb (09-01-2022), rickpaw (09-02-2022)
