Old 06-11-2022, 07:57 AM
Bobsky Bobsky is offline
Default LT4 C&R Radiator hose recommendation
Hi, Any suggestions on upper and lower radiator hoses numbers?
1969 Camaro
LT4 Crate wet sump
Drive Junky Street Monster front
Holley pan (external oil cooler)
C&R radiator (to fit 1969 Camaro mounts)
Thank you
Old 06-11-2022, 12:43 PM
camcojb camcojb is online now
Might contact V8 Speed. They have molded hoses and maybe know the part numbers they used.
I usually take a welding rod or metal coat hanger and cut and bend it to fit. Then take the two pieces to the local auto parts store and look through their inventory for a hose that matches the bends.
Old 09-13-2022, 08:42 AM
glr0212 glr0212 is offline
I am at the same point in my swap. Digging around to see what I can find.
How did you mount the Intercooler pump?
Old 09-13-2022, 11:06 AM
srode1 srode1 is offline
I think the LT4 and LT5 both have the same Corvette water pump so the hoses Mark Stielow used on his LT5 Camaro should work or be close since he had a C&R radiator. They are readily available. You can look at his build and do a visual check.
Dayco Hoses
E71703 Bottom
D71636 Top
The Following 3 Users Say Thank You to srode1 For This Useful Post:
camcojb (09-13-2022), dhutton (09-13-2022), Ketzer (09-16-2022)
