Old 09-07-2022, 02:24 AM
Colorado80439;
Does epoxy primer let in moisture like regular primer or isn’t it as porous?
Thanks,
Jimbo
The Following User Says Thank You to Jimbo1367 For This Useful Post:
syborg tt (04-26-2023)
  #22
Old 09-07-2022, 05:47 AM
dhutton dhutton is online now
Originally Posted by Jimbo1367 View Post
Colorado80439;
Thanks,
Jimbo
Quality epoxy is not porous and when properly applied it will block moisture.
The Following 3 Users Say Thank You to dhutton For This Useful Post:
camcojb (09-07-2022), colorado80439 (09-07-2022), syborg tt (04-26-2023)
  #23
Old 09-10-2022, 08:55 PM
colorado80439 colorado80439 is offline
Tubs and Quadralink
The Following 6 Users Say Thank You to colorado80439 For This Useful Post:
camcojb (09-11-2022), fleetus macmullitz (03-04-2023), Ricochet (02-27-2023), Roscoe03 (09-15-2022), syborg tt (04-26-2023), WSSix (09-12-2022)
  #24
Old 09-11-2022, 10:24 AM
Very nice work.
colorado80439 (09-11-2022)
  #25
Old 09-12-2022, 09:23 PM
Musclerodz's Avatar
Colorado80439;
Thanks,
Jimbo
PPG DP90 will. Its not what it used to be. If left exposed it will last about 6 months before rust starts to show.
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-13-2022, 05:48 AM
I quit using DPLF many years ago. Overpriced junk imho. SPI epoxy is all I use. Better product for less cost than DP.
camcojb (09-13-2022)
  #27
Old 09-13-2022, 04:59 PM
Unhappy
dhutton,
What’s DPLF ? Sorry, lol. Does the SPI have any problems with solvent or water Bourne paints? What do you put down for a sealer?
Thanks for any info you can provide.
Jimbo
Old 09-13-2022, 05:54 PM
DPLF is the new lead free version of DP. It was never the same once they took the lead out. It can’t be sanded and the price is outrageous for what it is.
Epoxy can be used with any solvent or waterborne paint.
For sealer I use reduced SPI epoxy. There is a lot of information in the tech sheet on their website.
So my usual build is bare metal, SPI epoxy, filler and/or polyester primer in the epoxy recoat window, epoxy, urethane primer in the epoxy recoat window, and reduced epoxy sealer just before base coat.
Sort of hijacking this thread. You can PM me if you have more questions.
The Following 2 Users Say Thank You to dhutton For This Useful Post:
camcojb (09-13-2022), syborg tt (04-26-2023)
  #29
Old 09-13-2022, 08:19 PM
Musclerodz's Avatar
I quit using urethane primer years ago because of shrinkage. Get it straight in poly, seal in epoxy and color. It eliminate a step and reduces the amount of material which also helps reduce shrinkage.
Mike Redpath
facebook page
The Following 4 Users Say Thank You to Musclerodz For This Useful Post:
camcojb (09-13-2022), colorado80439 (12-09-2022), dhutton (09-14-2022), syborg tt (04-26-2023)
  #30
Old 09-14-2022, 01:17 AM
Thanks guys !
Colorado80439,
Sorry about mucking up your thread.
