Old 09-17-2022, 07:55 AM
sru1436 sru1436 is offline
Looking great, I’m gonna have to get some of those mag daddy holders. I can use those in a lot of areas on my car.
The Following User Says Thank You to sru1436 For This Useful Post:
syborg tt (09-19-2022)
  #1852
Old 09-19-2022, 01:00 AM
I’ve seen those Velcro zipTies before, Yet I’ve never thought about where they could prove useful. Thanks for showing me lol. Great idea
The Following User Says Thank You to Jimbo1367 For This Useful Post:
  #1853
Old 09-19-2022, 10:15 AM
syborg tt's Avatar
They are not cheap but man do they work great. You can play with the harness till you get it exactly where you want it and then your done. I have considered a small dab of panel bound once I am happy with the final location of each of the mounts.
Originally Posted by Jimbo1367 View Post
I’ve seen those Velcro zip ties before, Yet I’ve never thought about where they could prove useful. Thanks for showing me lol. Great idea
You're welcome and always glad to share the knowledge that I have been exposed to along the way.
marty-mj
camcojb (09-19-2022)
  #1854
Old 09-19-2022, 10:57 AM
syborg tt's Avatar
Default Trying to find the easy way out (( 06-05-22 ))
So I am running the DSE wiper harness under the steering column so it looks somewhat factory. However I am trying to come up with a solution to retain the line clamp. Since the hardware isn't a machine thread there really isn't a nut available. In the end I should have just drilled out the holes and tapped them for an actual bolt and then I could just use a nut & washer in the engine bay.
Attempt #1 License plate nut. -- Fail
Attempt # 2 I forgot what these are called. -- Fail
They kinda work but not really
In the end I am just going to drill & tap the holes and do it the right way.
marty-mj
  #1855
Old 09-19-2022, 01:27 PM
syborg tt's Avatar
Default Holley Sniper Intake Manifold Fittings (( 06-05-22 ))
Time to finally finish the intake manifold so I can install it in a couple weeks.
So does this stuff ever dry ?
marty-mj
Old 09-19-2022, 01:33 PM
syborg tt's Avatar
Default Drivers Side Fender Paint ((06-09-22))
I decided to paint the back side of the fenders.
Fender is finally home and will soon be on the car.
Prepping the car so I can install the fender.
It's nice finally removing some of the blue tape.
I am happy that I had Larry paint the firewall satin black as it is a nice contrast with the body color.
Hopefully, I can get Mike or Scott to come over and give me a hand to install the fender soon.
marty-mj
Sonar Chief (09-19-2022)
  #1857
Old 09-20-2022, 04:24 AM
sleepertime's Avatar
sleepertime sleepertime is offline
Post A little late to the party, But...
These were once much more expensive and harder to find. This is one that found and use for a number of projects with a great size selection. You can also get all of the sizes of rivet nuts in stainless. https://www.amazon.com/Giantisan-Pro...NsaWNrPXRydWU=
My build BRNAGN 1969 camaro SS
The Following 2 Users Say Thank You to sleepertime For This Useful Post:
camcojb (09-20-2022), syborg tt (09-20-2022)
  #1858
Old 09-20-2022, 07:08 AM
That’s a really fair price. IMO
  #1859
Old 09-20-2022, 10:38 AM
I love rivetnuts...
  #1860
Old 09-20-2022, 10:51 AM
syborg tt's Avatar
Wow that is cheap and I will be adding this to my Amazon Shopping list.
I love rivetnuts...
As do I
marty-mj
