Old 10-15-2022, 08:32 PM
That oil fill cap is pretty slick. Will you keep it body color?
Old 10-16-2022, 09:00 PM
colorado80439 colorado80439 is offline
That's the plan for now
Old 10-17-2022, 08:25 AM
Installing the drivetrain for mock up
The Following 4 Users Say Thank You to colorado80439 For This Useful Post:
fleetus macmullitz (11-06-2022), Goosesdad (10-17-2022), syborg tt (04-26-2023), waynieZ (10-26-2022)
  #54
Old 11-02-2022, 08:41 AM
Engine, transmission and rear end are in. Setting drive line angles measuring for the driveshaft, fabricating the tunnel to the Tremec., but first we looked for a trans cross member. We looked for something strong but would allow enough room for a 3 inch exhaust to tuck nicely under the floor. The bottom cross member came from Bowler, the middle Chris Alston and not sure where the top one came from.
The Following User Says Thank You to colorado80439 For This Useful Post:
  #55
Old 11-02-2022, 09:10 PM
After test fitting the transmission cross-members we decided to go a different direction and Kennedy fabricated a cross-member that's welded to the floor and rockers. In a discussion with Sled Alley it was suggested to use a rubber transmission mount to avoid vibration issues.
The Following 6 Users Say Thank You to colorado80439 For This Useful Post:
camcojb (11-03-2022), dhutton (11-03-2022), fleetus macmullitz (11-06-2022), Goosesdad (11-09-2022), Roscoe03 (11-10-2022), syborg tt (11-08-2022)
  #56
Old 11-03-2022, 09:11 AM
A DSE crossmember. Nice
Old 11-03-2022, 05:26 PM
Tempstop Tempstop is offline
I was curious about your steering column firewall mount. Could you give me some details?
Old 11-03-2022, 08:02 PM
camcojb camcojb is online now
Old 11-06-2022, 09:48 AM
It's just an ididit steering column firewall mount. It's been a while but it may be Borgeson product, they make good stuff!
Since then we returned the Ididit column and went with a GM tilt steering column.
The Following 3 Users Say Thank You to colorado80439 For This Useful Post:
camcojb (11-06-2022), fleetus macmullitz (11-06-2022), Tempstop (11-06-2022)
  #60
Old 11-08-2022, 08:59 PM
syborg tt's Avatar
Those Welds
Wow !!!
marty-mj
colorado80439 (11-09-2022)
