Old 10-18-2022, 01:36 PM
Wow nice time!
The Following User Says Thank You to waynieZ For This Useful Post:
kwhizz (10-18-2022)
Old 11-01-2023, 06:41 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Had the car out at the drag strip again and left the line at idle and drove it down......12.25 @115 and 12.26 @115.....Crazy....Back in 66 I had a L-79 Nova that ran 13.10......LOL
The Following User Says Thank You to kwhizz For This Useful Post:
camcojb (11-01-2023)
Old 11-01-2023, 07:09 AM
kwhizz's Avatar
Another issue that popped up recently that others should think about when installing coil-over shocks in the front of the car......In the stock configuration the coil spring sits on the lower control arm and the top of the spring is seated in the inside of the frame.........When switching to coil-overs all the weight of the car is now carried by the top of the shock.......and that load is now carried by the old upper shock mount.......See where I'm going......LOL......[IMG][/IMG]
Had to take it to a Frame shop to get it pulled back into position, they welded it but when I got back home I was still uncomfortable with the situation so I made up some 1/8' thick gusset places and welded them in on both sides..... Just adding some more info out here for others to think about if you are in the same situation
Old 11-01-2023, 07:18 AM
andrewb70's Avatar
What was the 60 foot time?
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
Old 11-01-2023, 08:00 AM
kwhizz's Avatar
Andrew
2.07
Old 11-01-2023, 09:43 AM
Car runs good Ken! I've seen that failure on the frame before.
kwhizz (11-01-2023)
