10-01-2022, 07:32 AM
Upgraded 1st gen subframe, Hydroboost, Baer, C5 Acc. drive
All items have been sold.
1st Gen Camaro subframe SOLD - Complete front subframe and suspension. Just add brakes of your choice, wheels and bolt it to your ride.
- OEM subframe sandblasted and powder coated satin black
- ATS 670 steering box with rag joint coupler
- AFX Spindles
- Fast ratio steering arms
- SPC Stage II Upper and Lower Control arms
- Varishock double adjustable front shocks
- Helwig swaybar
- Hotchkis 2' drop coil springs
- S&P LS Swap brackets
- Stainless steel brake lines
- Replaced inner/outer tie rods
- Hotchkis tie rod sleeves
C5 Corvette accessory drive - SOLD!!! Hydroboost and Master cylinder - SOLD!!! - Hydroboost base model purchased from Hydratech
- Hydroboost has stainless steel slip cover
- Baer Remaster, 1 1/8" bore, black (has about 1,000 miles on it)
- Baer proportioning valve, mounting bracket and lines
- I can include the stainless steel lines and fittings
Rod
1969 Camaro - LS2/4L70E
10-18-2022, 04:27 PM
Price lowered on subframe from $3,700 to $3,300
Rod
The Following User Says Thank You to rocketrod For This Useful Post:
10-23-2022, 11:42 AM
C5 accessory drive has been SOLD.
Rod
10-25-2022, 01:32 PM
Subframe has been removed the car and the price lowered from $3,300 to $3,000
Rod
11-03-2022, 09:59 AM
Sale Pending
Rod
11-09-2022, 08:07 PM
All items sold.
Rod
